Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 01-20-2022, 10:46 AM
bryanchughes bryanchughes is offline
Default Carbon DB25 - Phase Issues
I freely admit that I may be missing something obvious, but I am using a DB25 to 1/4" TRS for the line outputs. I have lines 1/2 running to a mixer to blend with live inputs (not DAW related), but they are playing out of phase. The I/O is set up property (I think), and there is plenty of volume, but out of phase. The mixer takes balanced inputs. I also tried lines 3/4, and running into other devices as well. Thoughts, or am I missing something? Thanks in advance.
- Bryan
Old 01-20-2022, 12:07 PM
BScout BScout is offline
Default Re: Carbon DB25 - Phase Issues
What firmware are you on for the Carbon? (Also, since firmware is tied to Pro Tools, which Pro Tools?)
There was a phase/polarity issue with the Carbon (you can find the mention of it in the forum) that was fixed with a later firmware.
Pro Tools Ult 2022.4, HDX 3, MTRX/SPQ, HD OmniS1 x 2, FireHD x 2, Dock, iPad Mac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 01-20-2022, 12:18 PM
Thanks. Carbon firmware is: 1.0.3.1039 A
System: Pro Tools 2021.12.0, AVID Carbon, Mac-mini (M1, 2020) - 16GB running OS 12.0.1
I also reviewed other posts and was only able to see information on issues with phase using hardware inserts and nothing (that I saw) specifying upgrading firmware. Any help is appreciated.
Old 01-23-2022, 02:56 PM
Updating on this, I reached out through the AVID support center only to get a response that was associated with inputs, not outputs...my guess is they didn't read my question? In anywise, I responded immediately and have heard nothing back since. I reached out on the ticket again, so we'll see what comes of it.
Old 01-28-2022, 10:04 AM
JDubz70's Avatar
JDubz70 JDubz70 is offline
Hi Bryan,
Are you seeing this issue across all your sessions? Are you using hardware inserts? Which plug-ins are you using?
If you wouldn't mind doing a quick test and create a session with one stereo track (no inserts, plug-ins, etc) to see if you experience the same behavior and please let me know.
Thanks,
JW
AVID
Sr. Principal Product Manager - Pro Tools Hardware
Old 01-29-2022, 10:47 AM
Thank you but this is resolved now, and was my fault. Ultimately it wasn't Carbon, but rather the particular channel of the mixer I plugged the DB25 outputs into, was wired out of phase. I switched to a different strip on the mixer and it worked fine. My apologies, but thank you for the follow-up. Now only if PT 12 would work with the Apple M1 chip including all the plug-ins, then all would be well.
More Carbon Sync Issues...Must Get Solved... tomhartman Pro Tools | Carbon 42 04-21-2022 05:33 AM
Carbon Phase issues with hardware inserts alhardy Pro Tools | Carbon 4 12-30-2021 12:39 PM
FS: Avid DigiSnake 12 ft. DB25 to DB25 Cable (9940-29651-00) TVPostSound Buy & Sell 0 03-27-2017 12:14 PM
DB25 Male to DB25 Female Ext. Cable Barry Johns Pro Tools HDX & HD Native Systems (Mac) 11 06-12-2016 11:30 AM
Anyone know if a Tascam CU/SD105 db25 to db25 will do the job? juniperjuniper Pro Tools TDM Systems (Mac) 2 05-22-2002 12:30 AM
