Old 03-09-2010, 10:00 PM
Gohanto Gohanto is offline
Default Mute automation disabled?
I imported two sessions together recently for a mix (dialog in one, BGs and FXs in the other) and although I've got mute automation suspended, whenever I mute a BG or FX track they turn back on. I'll either mute a track while paused and it'll turn on when I hit play, or I'll hit it during playback and it'll turn back on if it hits a mute automation point.
The dialog tracks are all fine though, hitting the mute button is completely independent of any automation.
Any suggestions?
Good sound starts in the script, not in post-production.
Old 03-09-2010, 10:36 PM
Serge Perron Serge Perron is offline
Default Re: Mute automation disabled?
Suspending an individual automation parameter will only inhibit writing new automation for that parameter. The existing automation will play back unless the channel automation is in off mode. If you delete all the existing mute automation data on a channel, you can toggle the mute status at will on that channel regardless of its automation mode, assuming that mute writing is still disabled. If you want to modify the existing mute automation, you'll either have to edit it graphically and/or write enable mutes and the desired channels then write new mutes or remove existing ones.
Serge
Old 03-10-2010, 08:45 AM
jimlongo's Avatar
jimlongo jimlongo is offline
This has always been such a pain, OMFs and editing cause mute breakpoints in playlists.
You have to view mute automation and remove all of them.
noise | jimlongo
Old 03-10-2010, 09:41 AM
Caixen Caixen is offline
I've started using a handy key command to bypass the whole issue: pull up the mute automation on one of your tracks, and apple+click the automation pull-down menu -- mute will grey out and cease inciting fury. The logical extension is that apple+option+click disables mute automation on all the tracks.
Be careful to get the commands right though... I once did some combination of keys (probably involving 'shift' in some capacity) that disabled ALL the automation on ALL my tracks. Which was quite problematic until I was able to backtrack and figure out what had happened...
Old 03-10-2010, 09:49 AM
Norad155 Norad155 is offline
EDIT: whoops Caixen got there first... I need to type faster!
you can suspend the playback of individual automation parameters as well.
see here for selectively suspending one automation parameter.
I have mute automation writing and playback suspended in all of my templates. All automation reads and writes except for pesky mute automation.
IMDB
HTML code is On
Automation disabled on all tracks - help! pcv 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-26-2012 09:06 PM
Volume Automation disabled? PouPiam 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 07-20-2009 08:09 PM
Monitor control knob and mute disabled - it's just LOUD!! tpt1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-03-2007 05:08 PM
Mute Region or Mute Automation Jeremy Mix3000 Pro Tools TDM Systems (Mac) 9 01-22-2007 08:53 PM
One group's Volume automation mysteriously disabled wallah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 09-04-2001 02:47 PM
