Old 03-24-2007, 08:16 AM
jasonguitar jasonguitar is offline
Default M-Audio Firewire 1814 Sound cutting out
I'm using an M-Audio FW 1814, and I've installed the latest drivers. I have a Line 6 Vetta II combo amp plugged in direct to the FW 1814 via SPDIF cable. All of the sudden during playback, the sound cuts out even though all the levels are still going on all tracks. This happens randomly. Sometimes I can record for 5 minutes, and the sound drops out; sometimes I can go for an hour. The only way for me to get the sound back is to shut down and restart. Also, when this happens, the FW 1814 control panel window freezes. Any ideas about what's going on here? I've listed my specs below via Sandra.
Thanks.
Jason
SiSoftware Sandra
Processor
Model : AMD Athlon(tm) 64 Processor 3700+
Speed : 2.40GHz
Model Number : 3700 (estimated)
Performance Rating : PR4325 (estimated)
Cores per Processor : 1 Unit(s)
Threads per Core : 1 Unit(s)
Internal Data Cache : 64kB Synchronous, Write-Back, 2-way set, 64 byte line size
L2 On-board Cache : 1MB ECC Synchronous, Write-Back, 16-way set, 64 byte line size
Mainboard
Bus(es) : ISA AGP PCI IMB USB FireWire/1394 i2c/SMBus
MP Support : 1 Processor(s)
MP APIC : Yes
System BIOS : American Megatrends Inc. 1004.006
System : To Be Filled By O.E.M. To Be Filled By O.E.M.
Mainboard : ASUSTeK Computer Inc. K8VSEDX
Total Memory : 1023MB DDR-SDRAM
Chipset 1
Model : ASUSTeK Computer Inc Apollo K8T800 CPU to PCI Bridge
Front Side Bus Speed : 2x 800MHz (1600MHz data rate)
Chipset 2
Model : Advanced Micro Devices (AMD) Athlon 64 / Opteron HyperTransport Technology Configuration
Total Memory : 1GB DDR-SDRAM
Memory Bus Speed : 2x 200MHz (400MHz data rate)
Video System
Monitor/Panel : NEC MultiSync LCD1970V
Adapter : RADEON 9600 SERIES (DNA 2.4.4.4)
Adapter : RADEON 9600 SERIES - Secondary (DNA 2.4.4.4)
Physical Storage Devices
Removable Drive : Floppy disk drive
Hard Disk : WDC WD800JB-00JJC0 (75GB)
Hard Disk : SEAGATE ST3200822A USB Device
CD-ROM/DVD : SONY CD-RW CRX320EE (CD 52X Rd, 52X Wr) (DVD 7X Rd)
Logical Storage Devices
Hard Disk (C:) : 75GB (58GB, 77% Free Space) (NTFS)
CD-ROM/DVD (D:) : N/A
3.5" 1.44MB (A:) : N/A
New Volume (Z:) : 186GB (165GB, 89% Free Space) (NTFS)
Peripherals
Serial/Parallel Port(s) : 2 COM / 1 LPT
USB Controller/Hub : VIA Rev 5 or later USB Universal Host Controller
USB Controller/Hub : VIA USB Enhanced Host Controller
USB Controller/Hub : USB Root Hub
USB Controller/Hub : Generic USB Hub
USB Controller/Hub : USB Mass Storage Device
USB Controller/Hub : USB Composite Device
FireWire/1394 Controller/Hub : VIA OHCI Compliant IEEE 1394 Host Controller
Keyboard : Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
Mouse : Microsoft PS/2 Port Mouse (IntelliPoint)
Printers and Faxes
Model : Microsoft Office Document Image Writer
Model : HP DeskJet 950C/952C/959C
Power Management
AC Line Status : On-Line
Operating System(s)
Windows System : Microsoft Windows XP/2002 Professional 5.01.2600 (Service Pack 2)
Network Services
Adapter : Marvell Yukon 88E8001/8003/8010 PCI Gigabit Ethernet Controller
Performance Tips
Warning 100 : Large memory sizes should be made of Registered/Buffered memory.
Tip 2546 : Large memory modules should be ECC/Parity.
Notice 5901 : CD 1x= 150kB/s; Exercise caution when comparing measured versus published ratings.
Notice 5902 : DVD 1x= 11.08Mbps Exercise caution when comparing measured versus published ratings.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
M-Audio Firewire 1814 makes M/S sound odd anli Pro Tools M-Powered (Mac) 1 04-23-2008 05:51 AM
003 vs. M-audio firewire 1814 legacygone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-11-2008 07:41 AM
M-audio Firewire 1814 - anyone using it successfully? Richard901 General Discussion 5 05-28-2007 11:26 PM
M-audio Firewire 1814??? sethbrand Pro Tools M-Powered (Mac) 2 03-13-2007 10:55 PM
M-Audio Firewire 1814 can't see 8 inputs nickpell Pro Tools M-Powered (Mac) 2 11-29-2006 06:09 PM
