Old 02-01-2007, 09:24 AM
mhvoiceuk mhvoiceuk is offline
Default No sound when playing back with record enabled
I have PTLE 7.1 with a Digi 002 Rack. I recently upgraded from 6.9 and I notice that some things are shifted around.
I can't hear playback when record is enabled and I have to click it off in order to hear playback. Also Pre-roll now doesn't work
-presumably for the same reason, as record is enabled when I'm using pre-roll. Is this simple - do I just have to change a setting or is it a known issue ?
Any help much appreciated.
Old 02-01-2007, 12:27 PM
flommer flommer is offline
Default Re: No sound when playing back with record enabled
It sounds like an input monitoring setting issue..
Under the track menu you will find either "Input Only Monitoring" or "Auto Input Monitoring"
Whatever you have set, try changing it to the other..
I don't think this affects pre-roll but I could be wrong.. Can't test I'm away from my Mac..
Search the manual for pre-roll and see what you find...
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
No Input sound when Record enabled joechucknorris FireWire & USB Audio Interfaces (Mac) 5 11-03-2014 05:10 PM
playing VI´s without record enabled? clausiii Virtual Instruments 2 02-20-2009 04:00 PM
playing VI´s without record enabled? clausiii 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 02-20-2009 09:20 AM
VI´s playing without record enabled clausiii Pro Tools M-Powered (Mac) 0 02-19-2009 03:58 AM
No sound with record enabled... mgeiger 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-13-2008 07:30 PM
