Anyone else periodically lose the ability to remove from a session or delete audio files with the keyboard command?
I do once in a while, and need to restart in order to get it back. I have PT 5.0.1. Never experienced it before the upgrade. Mark
Mark |
Mark
i tried this with Pro Tools ver 5.0.1 45 times in a row and could not reproduce your problem. Please provide system info (CPU, MAC OS, Pro Tools Ver and Hardware. MJ Digidesign Tech Support |
I have also had similar problems, Cmd Shift R which used to Rename Regions now sometimes brings up a Repeat dialog and sometimes just doesn't work.
Also the right and left keyboard arrows that bounce you to the start or end of a region seem to not always work... |
Trombino,
I've had this problem, and I'm not suggesting in anyway you're as much of a space cadet as i am... Make sure all the regions are showing in the regions list. Use "Find All" command, and show auto-created as well. They seem to have to be visible on this list for the command key to find and remove/delete them, even if the regions are on tracks and selectable/visible. I also restarted to get this back, but eventually noticed that I had inadvertently "found" a small number of regions, which then can't be selected from the point of view of the region list. [This message has been edited by johnwhynot (edited July 07, 2000).] |
hard to tell exactly what problems everyone is having, but here's my observation since 5.0 -- sometimes (and I can rarely figure out the rhyme or reason) my command-shift commands don't work. One example that I can pinpoint is that when trying to save plugin settings, command-shift-S doesn't save the plugin settings, it's a shortcut for Save As... on the session. Another is that with the ChannelStrip plug open, command-shift-E returns the plugin to it's factory default instead of inserting space. I've also noticed some weird things with command-shift-B and others and the only way I've found to make them work properly is to reboot -- of course, usually I just quietly use the pull down menus instead so that the client doesn't watch me reboot.
I thought QuickKeys might be at fault, but I don't think so -- although I should try disabling it altogether sometime... |
I'm glad it wasn't just me imagining that sometimes apple-shift-B doesn't work. It happens only sometimes, just as you all have experienced it.
by the way, I just checked my quickkeys and the cmnd-shift-S thing was operator error. oops. but the cmnd-shift-E thing wasn't, and the cmnd-shift-B thing is still a mystery.
Lost use of "<SHIFT><COMMAND> H" today using v5.0. Rare occurence.
later, j mcd |
Well... I'm glad it's not just me for a change
![]() johnwhynot - Hi! I usually choose to not display auto-created regions. Next time this happens I'll see if that has something to do with it... MJ - here's my setup: MixPlus + 1 farm card PT 5.0.1 MacOS 8.6 9600/300 but with a (gasp) Newertech G3/400 256MB RAM (35MB to PT, 35MB to DAE) (I think) I forgot to mention that the first time it happens, the region or soundfile I'm trying to remove will just be removed from the playlist, and I don't get the panel asking me if I want to remove it from the session or delete it from disk. The region is still in the session, and I can use the audio menu to get rid of it. After that, the key stroke command doesn't do anything. And then, SOMETIMES, the command will start working again... KingTor - I've also experienced once that the command-shift-s didn't save plug-in settings. I forgot about that. Are you sure it was QuickKeys? I don't have that installed on my system... [This message has been edited by trombino (edited July 09, 2000).]
Mark |
About the shift-cmd-XX keyboard shortcuts, I had this problem many times, especially using G4/macOs9 (but can't be sure it didn't happen on G3/8.6)
In fact, when the bug occurs, every keyboard shortcut that uses the "shift" key seems to not work anymore after some time, even the "alt-shift-3" function. Just save, quit, re-open the session and everything works fine ... until the bug occurs again ! I use these shortcuts very frequently, and when they break, I really miss them, but not easy to quit and reload the session when you're with a customer. I can just confirm there's a bug here. I thought it was caused by the USB/ADB converter (I used an ADB keyboard on the G4), but I noticed the "shift" key still work fine on the desktop even when it fails to work under Protools. So I guess this is a Protools bug, and not the ADB/USB Driver's fault. The fact that "to relaunch PT without restarting the computer" seems to fix the prob brings me to the same conclusion... Any Digi word about this ? Thanks! |
the Shift+Alt+Pom+click command | groovbro | Pro Tools TDM Systems (Mac) | 3 | 10-26-2008 06:45 PM |
SHIFT COMMAND WHY | germ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 12-12-2003 05:20 PM |
Trim to fit command? I think I'm losing it! | mondoJML | Tips & Tricks | 1 | 12-05-2002 12:08 AM |
Nudge vs Shift Command | lcpellerin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-04-2001 01:53 PM |
Can't "shift-command-B" sometimes... | dans | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-22-2000 11:38 AM |
