record (playback only 256 up ) why 128 no record
I have pc
core 2 duo 3.0 materbord gigabyte g31m-es2c ram 4 gb vga crad xfx 256 only record up to 256 digi 002 rack why ? |
Re: record (playback only 256 up ) why 128 no record
http://duc.digidesign.com/showthread.php?t=193637
http://duc.digidesign.com/showthread.php?t=133039 Start with these 2 threads
Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
I have 002 rack
Still need more info as mentioned earlier by albee1952.
So your system isnt showing a buffer of 64 at all? Are you saying it does but PT will only you allow you to record at 256 but not lower? Or...are you getting errors at lower buffer settings? Are you using VI's? Which ones? Any plug-ins inserted at all when doing this? If you're getting error messages, what are they? Basically, we need TONS of detailed info to even begin speculating and offering troubleshooting suggestions. Shane
One thing at least seems to help
I was able to go then down to 128 on a T61 with XP and PT8LE is to disable both WIFI and LAN extention from the device manager. there's also a new RiCOH script here if your firewire card is RICOH Also daisy chain computer<>drive<>Digi002
G5 2 Ghz, Digi002, Protools LE 6.7, Logic Pro 7.1 Mac OS X.3.9 / T61 vista Protools 8 for the road Paris France |
hallo mr .Shan
buffer 64 and 128 > stop no play no record blanck session only 1 track same error massege no plugins in session errer massege chk the playback > 256 , 256 and 1024 ok --------- I have other pc core 2 duo 2.8 materbord intel ram 4 gb vga crad xfx 256 very good recording 128 ok no error no massege |
Sayed,
There are a lot of different things that could be causing your problem, so it make take a little time to rule out various causes. But I think your problem is fixable. Just looking at the info you have provided, your problem sounds a lot like others have had with a Gigabyte board and a high-end nvidia video card. I would guess that if you are able to play at high buffer settings like 512 and 1024, then perhaps you are getting high latencies that are affecting your low buffer settings like 128 & 64. Various hardware can cause these problems. like video cards, network cards, wifi, and several other big offenders. You also have integrated video, so this should be disabled in the BIOS. That alone could be your problem, but you need to do a few tests. A good start is to download and run the DPC latency tester. If you are getting spikes, this could be the casue of your problem. It has been found that Gigabyte motherboards with some Nvidia cards have caused high latencies. This was mostly fixed by using the Microsoft video driver instead of the Nvidia driver. The only problem with this is that you will only be able to use one monitor as MS does not support 2 monitors. So,if your problem is the DPC latency and the Nvidia video card, this could be a good solution. Please let us know the exact model of Nvidia card you have and run the DPC latency Checker. Good luck.
John-Q6600,GA-EP35-DS3P, Zigmatec S1283: 235 D-Verbs @ 2.4 ghz |
thank you mr.JPS
Ok I Chk The Gigabyte motherboards and Nvidia cards ok I go to checker now ((DPC latency Checker)) |
Sayed,
You can call me John. You will find the DPC Latency Checker here: http://www.thesycon.de/deu/latency_check.shtml
Can't Record and Playback? | iFengo | Pro Tools 10 | 2 | 12-12-2012 12:37 AM |
Press Arm Record then Play and have to wait 3 miniutes before record/playback starts | The Muphin Man | Pro Tools SE and Essential (Win) | 8 | 09-10-2010 07:03 PM |
Playback/Record | 4times4mil | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 03-13-2007 02:52 AM |
playback and record lag | duanebonney | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-20-2004 03:40 PM |
**STILL** Bad record/playback bug in 6.1??? | pedrohead | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 09-20-2003 11:37 AM |
