DSP capacity problem on TDM Mix 24
I am running 6.4.1 TDM mix. I have a dual processor mac 1.25 ghz Power PC G4 with 1.5 GB DDR SDRAM. My TDM system has a core mix card, three mix cards, and a smaller dsp card. 4 cards in all. My interfaces are twp adat bridges and an 882.
Problem is - I have use of an extremely low amount of DSP processing power. I should have considerably more considering the 3 mix cards and single DSP card. I check the "system usage" option and find that cards 3 and 4 are not showing much usage. Only 76 of 256 TDM slots show usage. I did see when I clicked on the mix card name that many of the open space show that 100% has been allocated, yet I am not using them. HOW can I increase my DSP power with my current configuration. I had much more DSP power on my previous single processor 867 ghz, with only two mix cards. By the way, buffer size H/W and DAE, nor CPU usage limit adjustments seem to help the problem. WHAT SHOULD I DO? [email protected] |
Re: DSP capacity problem on TDM Mix 24
RAM Capacity | nexty76 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-29-2010 07:59 AM |
Large capacity Drives ?? | CharlesL | Storage Subsystems | 1 | 03-09-2007 01:33 PM |
How do I know my TDM capacity is exhausted? | c-post | Pro Tools TDM Systems (Mac) | 4 | 10-29-2002 12:09 AM |
symptoms of exhaustion of TDM capacity? | c-post | Pro Tools TDM Systems (Mac) | 11 | 10-24-2002 03:01 PM |
48 tk mix: drive capacity? | voravor | Storage Subsystems | 0 | 05-01-2000 07:04 PM |
