midi chunk list error
I use pt HD3 on powermac G4 PT 5.3.1
I made session with few midi information after a few times working in it, it gives me the message : Bad data encountered while translating MIDI chunk list. when opening and then it stops. making new session and importing tracks doesn.t work. so I started over again,.. after a while same problem....is there a solution? tnx |
Re: midi chunk list error
This error generally refers to a corrupt session file. Create a New Session and use the File>Import Tracks command to move the data into the new file.
Brent |
making a new session doesn't work, when importing it gives me the same error
i guess i have a serious problem here... anyone who wants to join me crying???
Do you have any backups of the session that open without posting the error?
If so, you can probably transfer the audio tracks from the most recent session file (the one posting the error) and use the older version to transfer the MIDI tracks into a new session. Brent |
tnx brent
I don't have an older backup of the session (to bad) I tried to import only the midi or only the audio tracks they both don't work, the only thing I can do is grab audiofiles out of the audio-folder [img]images/icons/confused.gif[/img] |
no answers yet?????
help.... |
Check your drive - its most prpbable that it is corrupted - I got these kind of midi chucnk errors with a faulty drive
tnx hocuspockus i'll try to change disks
MIDI chunk list error: Has Digi ever solved/addressed this? | joshuagrange | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-01-2009 04:41 PM |
MIDI chunk list error | Stiff | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 08-31-2007 04:20 PM |
HELP! Error: Midi Chunk List - cannot open session | SamiD | Pro Tools TDM Systems (Mac) | 2 | 02-12-2006 02:54 PM |
HELP! Error: Midi Chunk List - cannot open session | SamiD | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-10-2006 06:06 PM |
Midi Chunk List Error | Billy Bush | Pro Tools TDM Systems (Mac) | 4 | 01-28-2003 01:29 PM |
