Old 01-24-2007, 08:43 AM
ircswh ircswh is offline
Default Ozonic not being recognized by M - Powered in P4
I installed this a PC of mine as instructed.
1. Installed the Ozonic Drivers. Did a restart.
2. Then connected the Ozonic Keyboard. It installed itself flawlessly.
3. THen installed M-Powered.
4. Restarted
5. The Keyboard is fully recognized as the audio recording and playback device.
6.I open up M Powered and it says "Unable to locate the hardware"
EVerything is connected properly. It hooked up from a 6 pin to 6pin firewire cable that came with it.
I tried uninstalling the drivers and then restalling the drivers, but it made no difference.
Im running a Pentium 4 system
Win XP
1GB Memory
This computer only has M-Powered related software installed. iLOk is attached.
This once happened b4 on an Laptop , but I nevered fix it.
My current Laptop recoginizes the Ozonic fully.
Please Help
Old 01-24-2007, 09:33 AM
DigiTechSupt's Avatar
Default Re: Ozonic not being recognized by M - Powered in P4
Which version of the Ozonic driver and Pro Tools M-Powered do you have installed?
Avid Audio Tech Support
Support FAQ
Old 01-24-2007, 12:03 PM
I have the driver that came with the ozonic. When I went through the Firewire Ozonic Interface it says im using Ver. 5.10.0.5024
And im using M-Powered 7.1
Old 01-24-2007, 06:23 PM
spkguitar's Avatar
You definitely need to download the latest driver for the ozonic from the m-audio website.
The first version of the driver that was compatible with Pro Tools was 5.10.0.5036
The current version is 5.10.0.5036v2
Old 01-24-2007, 06:33 PM
spkguitar's Avatar
Also, while it is definitely best to download the latest drivers from M-audio, you really should follow the instructions included with the MPowered sofware. It's covered on page 10 of the MPowered getting started guide:
Pro Tools will not see your M-Audio interface
if you do not install the M-Audio driver
that is included with Pro Tools M-Powered
Structure+M Powered+Ozonic DaGrim420 Virtual Instruments 0 05-28-2009 08:19 AM
FireWire Not Recognized with Ozonic m01 Pro Tools M-Powered (Mac) 0 09-29-2008 03:26 PM
Ozonic not being recognized by LE 6.7 ircswh 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-07-2007 03:35 PM
Ozonic and M-Powered juanmaca80 Pro Tools M-Powered (Win) 5 02-14-2006 09:36 PM
Cant get Ozonic + M-powered oha Pro Tools M-Powered (Mac) 3 06-21-2005 06:47 PM
