can I trust the gain plugin's "find level" result?
hi out there!
Our problem is that we will check levels on a track or tracks using the gain plugin under Audiosuite, by selecting across what seems to be the highest amplitude area on the tracks, then clicking "FIND LEVEL" --we then get a peak and rms reading. We made no further adjustments. With no plugins active, and no volume automation changes -everything at default unity gain, we then Bounced the same selected areas, then reimported that bounced region into a session. Then we checked our bounce with the gain plugin again, expecting to find the same rms and peak. THEY'RE NOT THE SAME. We are getting discrepancies of anywhere from 1 to 4dB difference between pre-bounce and bounce when measuring with the gain plugin. What gives? Can we not trust the gain plugin? |
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? | bashville | Pro Tools 10 | 5 | 03-23-2013 04:04 PM |
Audible "Tick" at Clip Gain Pencil Points? | lowlights | Windows | 1 | 09-25-2012 03:25 PM |
Can't find "Convert Automation to clip based gain" | boinkpl | macOS | 2 | 11-03-2011 12:33 PM |
Pro Tools 9 slow audiosuite "Gain" performance issues | Epik Productions | macOS | 3 | 01-12-2011 01:29 PM |
Cant find Licence # in "My Digi" for "Reason" | jefflennan | MIDI | 1 | 09-08-2009 01:32 PM |
