Old 10-07-2011, 09:18 AM
gobertub gobertub is offline
Question Playback is coming from Mac rather then Monitors
I've never run into this before in 3 years using my system. When I booted up yesterday, the audio was playing back through my Mac speakers and not my monitor speakers. I assume there is some I/O issue, but not sure how to correct any settings. Over the last week, I have been using my 003 rack connected to a MOTU 8 Pre, so I can record 16 tracks at once. All has worked fine on the recording and playback until now. Any ideas?
Old 10-07-2011, 09:28 AM
CME CME is offline
Default
Sounds like pt9 defaulted to the aggregate audio device. Once you open a session go to your playback settings and switch it from the aggregate audio to the 003. It will have to reload the session but you should be good to go after that.
There is also a key you can hold when you launch pro tools that will allow you to select your audio device, but I'm not sure which one. N maybe?
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier.
Old 10-07-2011, 09:47 AM
Default Re: Playback is coming from Mac rather then Monitors
Thanks, I will give that a try.. It was maddening to deal with as it has never occured in 3 years using my system.. I assumed it was something in the IO settings..
Old 10-07-2011, 01:02 PM
Talisker Talisker is offline
Yup, the "N" key will do the trick and let you choose your device on startup
Mac Mini M1, 16 GB Ram, OSX 10.181.1,Focusrite Scarlett 18i20,Behringer ADA 8200,Pro Tools 2022 2xGlyph hard drive 750GB
[IMG] code is Off
no sound coming out through monitors BtotheZ26 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-23-2012 08:22 PM
No audio coming out of the Monitors?!?! Anthony Orsino 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-22-2008 09:21 AM
No sound coming from monitors shortyboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-11-2007 07:12 PM
Noise coming from Monitors part2 LucasM 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 05-04-2007 08:51 AM
No sound coming from my monitors on a Digi 002 digialltheway 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 02-12-2005 10:59 AM
