-6097 and -6086 a lot ... on G5/Panther!
So far - after two days of working on a first project I can say it is nice, powerful ... but somewhat not very reliable communicating with the 002R device.
I am working on a project (so far) involving: 16 Audio Tracks 13 moderate Plugins altogether Performed on a PM G5/1.6GHz 1.25GB Ram, External Maxtor 20GB Disk (in FW400 housing) as Audio Data Disk. I keep getting the error message: "Lost communication with 002. Please try increasing H/W Buffer Size or removing plug-ins and make sure you have a valid clock source (-6097)" and "The operating system held off interrupts for too long. If this occurs frequently increase buffer size (-6086)" quite a lot - even when there is nothing played back. The performance monitor indicated half CPU usage and kinda nothing on the others - yet the errors above occur?!? The H/W Buffer is set top max 1024. But I really do not want to decrease the number of plugins used. That was one of the reasons to move from an old G4/ to a G5. And 13 plugins even my G4 would have done under a Cubase VST (in OS9). Is there any other 'adjustible variable' within the Pro Tools environment to get this going properly?
--- Synclair ZX-81, 1024Bytes Free |
Re: -6097 and -6086 a lot ... on G5/Panther!
FOLLOW UP:
I actually moved the project now to the internal HD, disconnected the FW Drive, relinked and can confirm: it has nothing to do with my external HD. My next try will be the firewire port the 002R is plugged into - will try the front one in the machine instead. BTW: I 'disabled' about half my plugins used by now. Still get the errors with -6097 becoming my favourite since the last 6 years. I am actually having trouble to properly bounce the lot and sometimes even work at all since it occurs sporadically whilst I am 'touchin' no things. I think I really need serious help!
Play, 6097, 6086, 9128 Errors | tysteel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-30-2012 06:02 PM |
6086, 6097, 9128 errors solved | Londoner | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-29-2009 03:16 AM |
trouble shooting 6086, 6097, 9128 | sights | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-03-2008 03:11 AM |
Error Messages -6097, -6086, -9128 | onlyone-jc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 09-29-2006 11:16 PM |
End for the 6082, 6086 and 6097 errors LE 6.2.3 | mgoorevich | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 04-09-2004 04:13 AM |
