CoreAudio not recognizing MBox 2
Hello All,
any assistance would be truely appreciated. I am running protools 7.0 with an Mbox 2; Mac OSX 10.4.8 on a 2.1GHz PPC G5 with 1.5 GB of DDR2 SDRAM. Also, Logic Express 7.1.1, Ableton Live 5.2.2, and Garageband 3.0.4 My issue is this, i just finally upgraded to 7.0 last week and ever since have had a significant amount of noise coming from my Mbox. I believe i have pinned the problem down to CoreAudio. It would appear that CoreAudio is not recognizing my Mbox 2. When I open the CoreAudio Manager is reads as follows : Digidesign HW: Unsupported Device Status: Not Connected (HW not found) Channels: N/A Attached Clients: 0 Buffer Size: 512 When I click "connect" i get no response. However, in my Mac OSX Audio preferences it is listed and selected. Also, in my Audio/Midi Setup, the Mbox is available and selected. |
Re: CoreAudio not recognizing MBox 2
Hi
The MBox 2 doesn't actually use the core audio manager. It kind of has it built in, as long as you can select Core Audio as a driver in your sound prefs of your app you're away. Dan |
Mine is doing the same thing. Problem is, though, I'm running Peak Pro 5 and the input source appears for about 5 seconds on the Peak meters and then disappears. You can't get the source signal back. I've found that if I re-assign the source as "built-in line in" and then switch back to MBox 2 as source in Peak, I agin will see the input source on the meters for about 5 seconds and POOF! they're gone again. My work around at this time is to keep the input source as Built-in line input and connect the input cables directly to my 1.8GiG DP Power Mac with 2.5GB ram. Makes me wonder why I even bought the MBox 2?
I just got an M-Box mini which I'm running on a MacBook 2ghz core duo chip with 1 gb RAM with PT 7.1.1. Every couple times that I open a ProTools session I don't get any audio playback at all. If I reboot the sound returns. Any ideas what's going on? I thought it might be connected to the CoreAudio not recognizing my Mbox mini either, but if the above post is right, seems like something else is going on. I've been using a digi 002 for several years so I'm not used to the mysterious ways of the mbox yet.
MBox pro Gragaband not recognizing mic | MicPencilpoint | FireWire & USB Audio Interfaces (Mac) | 3 | 12-30-2013 07:41 AM |
osx not recognizing mbox | jack s. | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 05-25-2010 11:56 PM |
pro tools not recognizing mbox | chunkymutt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-24-2009 08:48 AM |
2 Problems: PT not recognizing plug-in and CPU not recognizing external hard drives | jasonguitar | Pro Tools M-Powered (Win) | 0 | 06-28-2009 06:32 AM |
SoundManager not recognizing Mbox ? | spaz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-16-2003 10:27 PM |
