Old 02-14-2014, 05:44 AM
finalmixaudio finalmixaudio is offline
Default Syncheck 3, worth it?
Hi guys... I do audio post for advertising, tv and film, and the video editors I work with usually give me a variety of video file formats which I noticed change the delay of audio sync. I consider myself to have a good eye to adjust the sync offset but then again it might not be perfect.
I found a device to measures video audio sync called syncheck3. Anyone here has used it? If so, is it worth the $500 price tag? Any pros and cons.
Thanks in advance
Old 02-14-2014, 06:41 AM
reichman's Avatar
reichman reichman is offline
Default Re: Syncheck 3, worth it?
Well, if you ever find yourself in the position of being with a client during a session and needing to tighten or adjust lipflap, you need Syncheck.
Those small quarter frame nudges that can make or break a convincing bit of dialog simply can't be done with confidence if you don't know how late your screen is.
The only downside of Syncheck for me was the discovery that most of the video cards and HD screens that audio studios use are jittery pieces of junk. You'll be surprised how much mush there is visually when you use Syncheck.
Nathaniel Reichman
Supervising Producer – Re-recording Mixer
Dubway Studios
Old 02-14-2014, 08:21 AM
Cheesehead Cheesehead is offline
I'd go so far as to say its essential.
How do you know if what you're seeing is in sync or not without
syncheck or something similar?
I agree its pricey, but its a specialized piece of kit.
Old 02-14-2014, 08:27 AM
crustn crustn is offline
We are using a neat little iPhone app called catchin' sync. It works very good (I think even better then syncheck3, we have both). Tested with a lot of different devices and has an accuracy of about 1 qfr.
Old 02-14-2014, 08:36 AM
mgoorevich's Avatar
mgoorevich mgoorevich is offline
Yes, buy the SyncCheck. If you consider yourself a pro you must tune your system with the measuring tools.
However the Synchcheck itself doesn't solve the problem. The only solution is to have a Sync HD, Black burst reference and the card which accepts it e.g. BM Decklink SDI.
Pro Tools for years relies on "floating" quick time movie which drifting for good without synchronisation noted above.
A better PT11 video engine is still under construction but will never be perfect either because the same technological limitations.
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
PT HD⎪N v2021.10 Ultimate ● macOS High Sierra 10.13.6
MacPro 2 x 2.93 GHz 6-Core Intel Xeon ● 24 GB RAM
MTRX Studio + MOM ● Sync HD ● AJA LHi referenced by AJA GEN10 ● D-Command ES24
Old 02-14-2014, 09:31 AM
mr.armadillo mr.armadillo is offline
We found Syncheck to be more accurate.
Old 02-14-2014, 10:03 AM
Peter Cole's Avatar
Peter Cole Peter Cole is offline
Thanks in advance
Syncheck 3 is only worth it if you are in the business of audio post. I rate it up there with pink noise and the 1K tone.
Old 02-15-2014, 02:27 AM
Schottlandru Schottlandru is offline
I received a foley session to edit with terrible production sound sync (makes editing to that impossible in itself), reyling on that "sync" to be correct (at first). The client was worth the investment in the device and I take it with me to every studio I freelance at. That and an spl meter, as well as the bluesky tones and Marti Humphrey's dolby tone he posted here some time ago.
Old 02-15-2014, 07:40 AM
paulo m's Avatar
paulo m paulo m is offline
Yes, a valuable tool. I have Syncheck 2 and when possible I´ll buy the version 3 which has lcd display, easier to check values.
Go for it!
Regards,
Paulo M
Old 02-15-2014, 12:54 PM
cananball cananball is offline
Totally worth it. I learned the hard way
Ken Wilkinson
http://kenwilkinson.tv
Pro Tools 10.3.9 HDN | HD Omni | Digi Command 8 | Artist Transport | Digi Surround Panner | Blackmagic Intensity Pro | JBL LSR4328 5.1
2.26GHz 8 Core Nehelam 8GB Ram OSX 10.8.5
HTML code is On
Wanted : Syncheck idris Buy & Sell 0 08-14-2012 12:27 PM
syncheck rental echomagic Post - Surround - Video 0 07-02-2012 03:59 PM
Reprieve or Canopus (Syncheck) idris Post - Surround - Video 14 05-25-2011 06:12 PM
Syncheck rocks... iamstudios Post - Surround - Video 13 05-25-2011 02:53 AM
Syncheck ii aurelio funk dias Post - Surround - Video 0 11-14-2009 08:02 AM
