Old 06-19-2006, 11:31 PM
evaclear evaclear is offline
Default Backwards compatibility of PT sessions
I am trying to open a PT 6.1 LE session that was created on a windows system (with mac/PC compat enforced) on a Mac TDM system running PT 5.1.3 Mix Plus OS9.2.
In doing so I have "saved session copy" backwards to a PT 5 session...however, when attempting to open the session on the TDM system (the drive i am using is HTFS), I am faced with the error -39. (answerbase wasn't overly helpful in this situation).
Does anyone have a possible solution for me??
evaclear
Old 06-20-2006, 05:03 AM
Drew Mazurek's Avatar
Default Re: Backwards compatibility of PT sessions
why are you saving back to a 5 session?
The format change occured at 5.1.
sessions from 5.1 til 6.9 are compatible.
www.drewmazurek.com
Old 06-20-2006, 08:28 AM
Shawn Simpson Shawn Simpson is offline
You also shouldn't try to open the session from the windows formatted drive on a mac. Copy the session to a proper drive and it should work fine in its current format, as pointed out above.
AAX and Backwards Compatibility with TDM Sessions ryan de topanga Pro Tools TDM Systems (Mac) 5 10-25-2011 06:33 PM
6.7 Backwards compatibility MilesMusic Pro Tools TDM Systems (Mac) 4 11-02-2004 08:48 PM
001 Backwards Compatibility$ mutation generation 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-09-2000 11:35 PM
PT 5.0 ..backwards compatibility SWAT Pro Tools TDM Systems (Mac) 5 01-17-2000 05:36 PM
Backwards Compatibility noizboyz Storage Subsystems 1 07-07-1999 05:37 PM
