Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
Old 07-26-2022, 11:23 PM
TrentWilliams TrentWilliams is offline
Default DADman Output Levels For Genelec Speakers
Hey all,
Does anyone know the maximum dbu input for a pair of Genelec 8040B’s? Trying to calibrate the output trims within DADman but the manual isn’t much help.
I’ve found this post, just want to confirm that based on this I should set the DADman output to -1.0 and the 8040’s to -6?
Pro Tools 2024.3.0|Perpetual • MTRX Studio • HDX1 • Sync-X • S3 • Dock • Mac Mini 2018 - 3.2GHz i7 6-core macOS 13.6 • RAM 64GB DDR4 GPU AMD 6900XT 16GB • Monitor LG 32UL950-W
Old 07-27-2022, 08:08 AM
creativecontrol's Avatar
Default Re: DADman Output Levels For Genelec Speakers
Greetings,
From the Genelec site:
The nominal analogue input sensitivity in Genelec studio monitors is -6 dBu which produces 100 dB SPL audio output at 1 meter in an anechoic room.
The nominal digital input sensitivity is set so that a 0 dB FS digital input produces a theoretical 130 dB SPL sound level at 1 meter in an anechoic room.
In DADman (with MTRX Studio) the DA section has a 6dB Gain switch which toggles the following:
Disabled: -66 dBu to +18 dBu
Enabled: -60 dBu t0 +24 dBu
The flagship MTRX supports +24 dBu max at the DA outputs.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 07-27-2022, 12:23 PM
Originally Posted by creativecontrol View Post
Greetings,
Jeff
Thanks for your reply, yeah I’ve read this a few times in the manual, I’m still trying to get my head around it all.
I’ve found this which does a better job of explaining things.
The input sensitivity setting in Genelec speakers is defined as the level of the input signal required for 100 dB SPL at 1 meter distance. So if you set the sensitivity setting to the maximum i.e. -6 dBu, it means that the speaker outputs 100 dB SPL at 1 meter distance with -6 dBu input signal level. In another words, when the maximum output of the speaker is 110 dB or more, you will need at least +4 dBu signal to push the speaker up to its limits. With + 6dBu sensitivity setting (min) a level of +16 dBu would be required. If your source device isn't capable of outputting such signal levels, you should increase the sensitivity setting on the speaker.
Old 07-27-2022, 04:20 PM
Here’s a description of attenuating and setting trims in the monitor profile along with REF to create a locked standard monitoring level:
https://avid.secure.force.com/pkb/ar...vel-in-Pro-Mon
Best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
MTRX/DADMAN output to multiple Spkr Outputs simultaneously with same stereo source? Jared_TL Pro Tools | MTRX & MTRX Studio 18 12-06-2021 12:51 PM
WTB: Genelec Speakers 80xxA speakers and a 7050B antonis Buy & Sell 0 03-31-2019 02:53 PM
Problems with sound leaking on Mbox2 Pro on my Genelec 8040A monitor speakers chrisdee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 09-22-2008 03:43 AM
Speaker stands for Genelec / Mackie size speakers tigeba Tips & Tricks 1 07-12-2001 10:54 AM
Genelec monitor speakers ponecollector Tips & Tricks 6 11-06-2000 06:10 AM
