Remote control of Carbon Headphone Outputs
Hi there,
My Carbon hardware is remoted far away from my recording setup. Do the Headphone outputs show up anywhere in Pro Tools that is controllable? Would the best way be to set a nominal level on the front panel headphone amp, then route the tracks I want to a bus , then make an aux track of that bus to headphone output in Pro Tools, and control that aux track with Avid Control? There is no direct hardware access to the headphone port that I can find in Pro Tools, is that right? Same goes with Avid Control, no direct access to that hardware gain control knob for the headphones. Debating on using this method or just getting a DB25 breakout to an external headphone amp that I can localize in front of me. Shame to not use the built in headphone amp in Carbon though. Thank you for you help on this! Matthew
MacBook Pro 2020, 2.3 GHz Quad-Core i7, 32 GB Memory, macOS Catalina 10.15.17, Pro Tools 2021.7.0, Carbon Interface |
Re: Remote control of Carbon Headphone Outputs
The advantage to this is I have a fader control in protools to adjust the master level, plus I can control that from the avid control app on my iPad. I do think avid should allow more than one iPad for this and some sort of "user layer " page to build simple headphone mixes for artists on an iPad. literally like 16 faders that you can Drag or assign whatever you want in your mix that the artist can turn up and down. hope that helps! |
Carbon - can the “Main Monitor” outputs be configured as just “outputs”? | massivekerry | Pro Tools | Carbon | 3 | 10-26-2022 02:12 PM |
Carbon Headphone Amps | Kamino Studio | Pro Tools | Carbon | 1 | 06-02-2022 11:58 AM |
Remote Recording On Carbon | trimix | Pro Tools | Carbon | 2 | 04-26-2021 11:36 AM |
*not* use the headphone outputs on the Carbon, and use my MacBookPro instead? | MixerGuy | Pro Tools | Carbon | 15 | 04-16-2021 06:12 AM |
D-Control Es32 Control Surface No Sound from Headphone outputs | mark007 | Pro Tools TDM Systems (Mac) | 0 | 02-08-2012 07:03 PM |
