Old 08-04-2008, 06:59 AM
JeanDit JeanDit is offline
Default PT on a Mac Mini ? Possible ?
Hi guyz,
My old PC laptop doesn't do the job (and it's not a supported setup for pro tools either) so I'm willing to give Mac a try.
That being said, I know nothing about Macs, at all. Can I go with a Mac Mini ? They are very cheap and seems to have somewhat power.
I was wondering:
My need: With a MBox2 Mini, the last pro tools version, and the needs to record vocals one track at the time and loading less than 20 tracks a the same time in a project.
Also - I'm seing a lot of 5400 RPM drives with Macs, it is enough ? Is Macs offering faster drives ? Should I worry about it ?
Well sorry for all these nooby questions, but no one in my surrounding can answer them!
Any advice ?
Please help!
Thanks in advance, this is much apreciated. <3
Old 08-04-2008, 08:47 AM
Phil Ogden Phil Ogden is offline
Default
Whilst it's not been tested (and qualified) with Leopard, the Mac Mini should work OK.
You should budget for an additional external FW 400 drive (with Oxford chipset) as recording to the internal system drive can be problematical particularly with a 5400 rpm rating.
I'd bump up the RAM to 2Gb too.
I take it you appreciate that the Mini does not come with keyboard and monitor so these are a further expense if you don't have them already.
http://www.myspace.com/philogg
Old 08-04-2008, 09:07 AM
Holly73 Holly73 is offline
Default
I also don't think the Mini is the cheapest way to get a Mac. Especially as the cheaper one has no Superdrive and a very little harddrive. But if you already have a decent monitor, it could be an option. Otherwise you could take a look at the iMac. It comes with 20" monitor, keyboard, mouse and other nice things like built-in webcam. It also has got a bigger harddrive (7200rpm) an Superdrive. All in all I'd say it's better bang for the buck.
But like Phil said, you'll need an external Firewire drive anyway for both of the above Macs. Same goes for another GB of RAM, but this should be no problem, as it is quite cheap now.
 MBPr 15" (Mid 2015) i7, PT12.4, Studio One 3, UA Apollo Quad Firewire
Old 08-04-2008, 11:54 AM
dougied dougied is offline
Talking
It is awesomely possible!!!!! I have a Mac Mini Intel Core Duo 1.66 with 2 GB of RAM and I have a Glyph external firewire drive hooked up with a Digi 002R and an ADAT 8 channel mic pre. You can track full-on bands with plugins and have no hassles at all.
I started out with a MBox Mini but then I wanted more mic pres so I then got my Digi 002R and ADAT rig setup.
not bad for a little $599 computer!!
Mac Pro Dual Quad 2.8Ghz 2008
MacBook Pro i7 2012
OSX 10.8.5 - OSX 10.7.5
Pro Tools 10.3.7 - 11.1.2
6GB RAM
Universal Audio Apollo Quad!!!
Eleven Rack
Focusrite Octopre MKII
Yamaha HS80s
Rockit RP5 Monitors w/ RP10 sub
Mac Mini, Mac Mini Server, or iMac? fretcruiser macOS 5 06-17-2012 10:37 PM
Am I Missing Something?! Mbox Mini, Mac Mini, Shockingly Bad gunark 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 12-07-2010 12:58 PM
Mac Mini and Mbox 2 Mini Issues neilwilsonvoiceovers 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-17-2010 09:34 AM
Any Mbox2 Mini/MAC Mini Intel Users? Need help with Reason Mbox2digi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-31-2007 07:37 AM
Mini Mac and Mini Stack questions Machinesound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-28-2006 10:48 AM
