Pro Tools in a Radio Station? Possible?
Is anybody out there using Pro Tools in a networked setup in a Radio station? How can PT be networked with an On Air Automated Workstation? Thanks in advance. |
Re: Pro Tools in a Radio Station? Possible?
hi raven
we use pro tools in an radio station, but not within a network. but as far as i know, austrian broadcast (ORF) does with their station oe3. i haven´t seen the system yet, but my collegues tell me they can import bounced files into their cartwall system with d&d or, alternatively playback a session on air. i don´t think they have a fader start connection to pro tools. sorry i haven´t got any links kp |
If you're using MACs, you can connect them via the ethernet ports and turn on AppleTalk to network them. We do this all the time to share video files at the TV station I work at (though ethernet is a bit slow for the size of video files, but for audio files and sessions it's fine. We can transfer about 1 gigabyte every five to six minutes during periods when the network is only handling a single transfer.
As far as an on-air DAW, I can't say I know anyone doing direct digital transfers to one. However, I do know one radio station which uses a DADPRO on the air but does all their production work on PT. They simply run PT through their mixer and accept that they'll have to do D/A to A/D conversion (the DADPRO is on a windows platform). When it comes to the actual on-air product, there's no way you can tell the difference. |
Thanks folks. On Mac or otherwise, if PT workstations can be on a network with the actual On-Air Automated Workstation it will be great. Can somebody give me an idea about the workflow?
Thanks |
For Automation we use BSI's Wavestation, for our simple needs we are on a peer to peer Win98 network. If you are using PT on a mac you can use a software called Dave, that will piggyback on your peer to peer using TCP/IP and allow you to become a shared machine. I know of one station that uses a Win 4.0 Server with a Raidto serve audio files to it's automation setup. You simple bounce the files out of PT and send them to the server.
It's a simple of matter of getting them networked and bouncing the files in a compatible format. Very easy!!!! |
Will RCS systems accept wave files? Are there any radio Stns running on RCS and networked with Digi systems?
Radio Station Equipment | jeffwuollet | General Discussion | 1 | 06-11-2004 01:49 AM |
What did the radio station do to the song???? | Jburn34 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 09-25-2003 03:31 PM |
Radio station compression settings | nobby | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 12-15-2001 05:13 PM |
Pro Tools in a Radio Station? Possible? | Raven | Pro Tools TDM Systems (Mac) | 4 | 08-14-2001 09:33 AM |
Digi001 radio station ! | Kickin.da.speaker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-28-2001 07:02 PM |
