#31
Re: MIDI in 2021 and BEYOND
The only time I’ve ever seen this is dragging and dropping a MIDI file from Stylus RMX onto a track in Pro Tools. The first note in the clip disappears and I found the weird thing is you can’t manually add it back! The workaround for me has been to import the clip, Consolidate it and then add the note, then it sticks.
Dave Marsden UK |
#32
Ah HA! Eureka! after your reading this I went and hit the "apple \" command and it appears that the midi clip went off to a playlist somewhere.. I sure would like to be able to access that playlist in the same manner that I access others tho... Any and all help in this regard would be most welcome.
Thanks!! |
#33
#34
#35
Mac mini (2018) 3.2 GHz 6-Core Intel Core i7 32 GB 2667 MHz DDR4 Mac OS Big Sur Pro Tools 2021.7 Pro Tools Carbon Interface |
#36
#37
#38
#39
Also as others have stated. Why you can't have it in Clips view when arranging and a separation cuts the midi note?? Nope. Your screwed. BASIC workflow... Midi needs an overhaul period! Why do all the composers not use Protools? "The Power to Create" as AVID says... Yeah right! The workaround is to use the competing daws to compose.... And AVID is the standard in FILM!!! Go figure! Protools chokes with most VI's. With one track! CPU overload/Spikes with a 128 buffer! Solution... Use VEP to host the VI's... What!!! Come on now! Buy more software from ANOTHER company to be able to compose in PRO tools.... My systems are up to speck with clean installs and up to date plugins. Doesn't matter. Its PRO tools....
Mac OS 12.7.2 Monterey (19H15) Mac Pro 2013 (Trashcan) 6 Core 64 gigs Ram, Red Line 16, Native Thunderbolt, ProTools Ultimate 2024.3.1 Macbook Pro, 2019 (15,1) Mac OS 13.6.6 Ventura,32 Gigs Ram,2.3 GHz I9 8 Core ProTools Ultimate 2024.3.1, Apollo 8 Silver,TwinX. |
#40
2021.6 and 2021.7 restart after exit | NJsound.com | Pro Tools | 12 | 08-11-2021 01:45 PM |
Cut/Insert Time still shifting markers & MIDI clips in PT 2021.6 | take77 | Pro Tools | 1 | 07-09-2021 10:53 PM |
2021.6 hangs when deleting audio or MIDI clips | innerbooty | Pro Tools | 5 | 07-02-2021 07:16 AM |
Update to 2021.3.1 now midi and software unstable | biggamen | Pro Tools | 9 | 06-03-2021 05:54 AM |
