Old 10-24-2005, 05:58 PM
H-man H-man is offline
Default How are you using Analog Channel?
I just ordered this plug. Just wondering how you guys are using AC 1 & 2 in your setup? How are you liking these two? I personally, cannot wait to get my hands on this plugin!!!!!
Don't be a puppet on strings!
Old 10-24-2005, 07:12 PM
Greg M Greg M is offline
Default Re: How are you using Analog Channel?
H-man,
Generally, I put an AC-1 as the first plug on the mix bus using what I think is an SSL Console preset. I put in on before I start mixing. As far as AC-2 goes, I usually put it on distorted guitar tracks (pick your favorite tape recorder model). IMHO these plugs really do help deal with "digital edge" and warm things up a bit.
Once you get the feel for using these plugs, you might also consider trying the DUY DAD Valve plug to add some more analog feel (subtle distortion) to your tracks. DUY has a nice 5 plug-in bundle for LE.
Hope this helps,
Greg
Intel i7 3930K, Gigabyte GA-X79-UP4 (rev 1.0), 32 GB Corsair Vengeance 1600 ram, EVGA Nvidea GT 720 TI video card, a Samsung 850 Pro (256 GB) OS drive, 2 Samsung 850 Pro's (512 GB) in externally mounted drive bays for session and sample storage, Win 10 Pro, PT Ultimate (Native)2019.10, HD Omni, HD I/O 16x16 .
Old 10-24-2005, 07:47 PM
Shan's Avatar
Shan Shan is offline
I use AC1 and AC2 on every mix I do.
Here is an AC 2 tip.
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 10-24-2005, 10:04 PM
rockrev rockrev is offline
AC1 on the master buss - always. I usually start with Console 1 or 3 (like Charles Dye suggests). I've used AC2 to help flatten a vocal track or two when a compressor/limiter simply wasn't cutting it. It will effect the EQ, but nothing that can't be managed with a little tweaking. Other than that, I'll use AC1 here and there to give a track a little more thickness (if needed).
As a side note, I find myself using Waves RenComp as a color/saturation effect lately. Try the "Kneeless Opto" preset as your first insert (trust me - it's a low ratio setting meant for this kind of thing). You'll have to pull the threshold down quite a bit, but it gives it a nice color - much less than AC2 and somewhat less than AC1 - but the color is there and it makes for a nice blend in the mix. It's been working out real nice in a jazz session I'm doing (where maintaining transparency is a must). Try it!
rockrev
End world poverty: ONE
Old 10-25-2005, 07:45 AM
yavuzj yavuzj is offline
AC! and AC 2 is not available for PT LE right?
Yavuz AKYAZICI
Guitar Player, Composer
http://cdbaby.com/cd/volcano
http://volcanojazz.com
http://myspace.com/volcanojazz
Old 10-25-2005, 07:56 AM
It's been available for a while now - works with 6.4 too (though they don't mention it).
rockrev
Old 10-25-2005, 08:46 AM
Ben B Ben B is offline
I don't really care for AC1, but I use AC2 quite a bit. Most often, I use it on the master fader (gently) to sort of glue the whole mix sound together. Sometimes it's just the ticket -- other times not. Overall, I'd say I've been happiest with the results when I use it sparingly.
-Ben B
Old 10-25-2005, 11:42 AM
Shan's Avatar
Been out for quite some time now.
Shane
Analog Channel(AC1) or Renaissance Channel Choral14 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-29-2006 07:07 AM
mcdsp Analog channel vs analog channel LE psus15 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 02-13-2006 11:45 AM
Analog Channel GregJ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-14-2005 07:33 PM
analog channel nwilson@hns.com Pro Tools TDM Systems (Mac) 4 10-19-2001 12:50 AM
analog channel drenched 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-16-2001 12:32 AM
