Hum-Like Noise Coming From Monitors When Pro Tools is Open
A high pitched hum, or whine, comes from my monitors only when Pro Tools is open.
I've searched the forums trying to find an answer to this and there's nothing I can find to sort out this problem. I've tried moving the USB cord to different USB ports on the back of my iMac, and I've tried using different cables running into the monitors. Nothing's worked. My setup is as follows: Mbox 2 outputs into Alesis ProLinear 820 Monitors Pro Tools v. 7.3.1. Apple Intel iMac v 10.4.7 Anyone please HELP! |
Re: Hum-Like Noise Coming From Monitors When Pro Tools is Op
This is common, have you got balanced cables in to the monitors?
Cheers
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D --- iCON Photography |
I have the same problem too. We need balanced cables? What is that and what does that mean? Excuse me if its a stupid question. Help is appreciated as always.
thanks
Digi002 Control Surface, Power Mac G5 Quad 4x2.5GHz 3GB , Lacie 320 GB Hard Drive D2, M-Audio Octane Preamp, Akai MPC2000XL, Korg Triton 61 Key |
Re: Hum-Like Noise Coming From Monitors When Pro Tools is Open
Balanced cables for sure...this is a must. Make sure you get some really good ones too, because you can get some cheap-o balance cables and still have the same problem...it's frustrating.
go with MOGAMI, the best...lifetime warranty. d |
thanks!
right now i have my digi 002 connected to my monitors with 1/4" RCA cables. i guess that is the problem. i'll go get those cables this weekend. hopefully thats the problem.
I'm having this same problem and I'm pretty sure it's nothing to do with the cables. Firstly, I already have balanced cables. Secondly and most importantly, the whine only began after I hooked up an external monitor using the same power strip as my monitors. If I unplug the monitor, the whine stops. And, naturally, the whine is only present when ProTools is running. I figure this is a grounding issue. Is there a solution that doesn't include powering the external monitor from another source? (ie another outlet) Thanks a mil
-J |
If CRT, you are probably hearing the horizontal oscillator. You could try a three to two prong power adapter. That will lift the ground on your monitor. But don't leave it that way since the monitor is no longer grounded. You could try moving the monitor away from the speakers. If all fails, try a flat screen monitor. I assume you are talking about a video monitor.
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. Last edited by Park Seward; 01-01-2011 at 04:25 PM. Reason: Typo |
Hum from Monitors while Pro Tools open | Legion6789 | Pro Tools 10 | 6 | 11-28-2011 06:36 AM |
Pro Tools 9.0 no sound coming out of my monitors | shamanrock | Windows | 2 | 08-05-2011 09:18 PM |
Noise coming from Monitors part2 | LucasM | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 17 | 05-04-2007 07:51 AM |
Radio Noise Coming Through Monitors | unclecolly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-20-2006 07:37 AM |
Noise coming through monitors from hard drive..... | silence2-38554 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 12-04-2005 06:22 PM |
