Old 08-08-2022, 04:33 AM
oortone oortone is offline
Default Write to next not working in Trim
Tested on ProTools Ultimate 2021.10.0
1. Ativate Latch and Trim on a track.
2. Open Volume graph for reference
3. Open Auomation Window
4. Activate "Write on Stop" : Next Breakpoint (the one with a right arrow and a dot)
5. Start playback somwhere where there's already automation written after the Playback cursor. Then write some automation.
6. Stop playback.
Now the trim offset should be written to the next break point.
Instead the trim offset is written all the way to the end, exactly the same as if "Write on Stop" : Write...To End, was active.
This only happens in Trim Mode, otherwise it's as expected.
This is a bug, right?
Old 08-18-2022, 02:49 AM
Default Re: Write to next not working in Trim
No one else seen this?
Old 08-18-2022, 07:17 AM
I can confirm the same behavior, using the steps you provided.
2019 MacBook Pro i9 2.3GHz 8-Core 32GB RAM
MacOS 12.4
PT Ultimate 2022.6
HDX/Sonnet
MTRX Studio
I would open a support ticket, if you haven't already. It's the best way to let the dev teams know about repeatable bugs.
Scott Gatteño
Old 08-18-2022, 08:01 AM
Sonopolis Sonopolis is offline
Confirmed, yes. Additionally Write to Next Automation Breakpoint on Stop writes to the end of the selection if you have on.
Old 08-18-2022, 08:03 AM
MacOS 12.4
PT Ultimate 2022.6
HDX/Sonnet
MTRX Studio
Yes, I'll do that. Where is the place to open such a ticket?
Old 08-18-2022, 12:52 PM
Log into your Avid account at Avid.com, then go to My Account. From there click on Access the Support Center (Portal).
File Type: jpg Screen Shot 2022-08-18 at 3.49.40 PM.jpg (38.0 KB, 0 views)
Scott Gatteño
Old 08-24-2022, 04:45 AM
OK, thanks. I work for a company so I don't have direct access to the accounts. But anyway... thanks!
Write to all not working on Trim Volume ? diane_son Pro Tools 2020 3 07-23-2020 03:21 AM
Write to All on S6 for LFE not working mjesmer Pro Tools 12 0 08-22-2017 08:03 AM
Write to All Enabled Still Not Working Cryos Pro Tools 12 17 03-29-2016 03:58 AM
Write Automation to End not working wyman ICON & C|24 1 10-06-2003 07:58 AM
