Latency with expansion chassis
I'm still using the now unsupported Digi HD expansion chassis. It has always doubled the latency of my system, at whatever buffer setting. My question is, do the Magma chassis' also double latency? I'm approaching an upgrade and am trying to decide whether to get new PCIe cards or use my old ones in a Magma chassis. I hate the extra latency.
Thanks, -R
rickkrizman.com |
Re: Latency with expansion chassis
Bruno |
Are you dudes sure about this// isn't PT chassis just really a magma chassis with a PT logo on it.
-don't take my word for it -check it out for yourself. cheers Bruno |
The Digi expansion HD6 was made by Digidesign and did induce extra latency. This chassis is no longer supported and does not work beyond 8.0.1 it was an ethernet connection and the drivers are no longer in the software. there were early chassis made by Magma with Digi branding. 13 slot and 7 slot and i'm not sure if they still work in the latest PT software!!! The Magma PE6R4 does not induce any latency!! and rocks and should remain compatible for a few years yet. Chris
Ok cause i use to own a 13 slot digi chassis and they where for sure made by magma back then was surprised that digi actually starting making there own so was sceptic about it be-in done internally or it's someone else then magma doing them now // mine use to work super great with 1 mixcore 3 mixfarms, 2 dspfarms and 2 samplecell tdm. |
Can anyone verify that the current Magma chassis do not introduce any additional latency, even with the PCI to PCIe conversion card?
-R
rickkrizman.com |
PE6R4-I revA1 +PCI HDcards +Quad Core Intel Xeon PCIe MAC + PT8.04 =no extra latency due to chassis
Do you guys think seeing the recent developments from Avid that chassis solutions will be supported for much longer?
We run a 7 slot Magma chassis, it does not introduce ANY latency into the system. It runs seemlessly with PCIe cards, i would certainly reccomend the Magma chassis!
RTAS latency with Expansion Chassis | roberts | Pro Tools TDM Systems (Mac) | 0 | 12-05-2006 09:58 AM |
Expansion Chassis VS 64 Bit Chassis Latency | Touchwood Studios | Pro Tools TDM Systems (Mac) | 2 | 08-09-2006 05:03 PM |
Expansion Chassis RTAS VI latency | plurye | Pro Tools TDM Systems (Mac) | 9 | 01-10-2006 08:00 PM |
Expansion chassis RTAS VI latency | plurye | Pro Tools TDM Systems (Mac) | 3 | 01-10-2006 12:18 PM |
How much RTAS latency with expansion chassis? | spiritG | Pro Tools TDM Systems (Mac) | 10 | 12-21-2005 11:10 AM |
