Old 10-14-2024, 08:57 AM
WAD WAD is offline
Default 2024.6 VERY laggy and slow..
I just updated to 2024.6 from 2022.6 - finally took the plunge on renewing the 12 months of updates. Did a clean install.. installed all my plugins again from scratch with latest versions.
And wow it's laggy.. it seems to start off generally ok and then get gradually worse. to the point where I'm moving a fader and it jerks along behind the mouse. the audio playback etc is all fine though.
I just wondered if this version is known for being a bit crap, and maybe I should roll back a few?
____
I'm on the latest version of Windows.. AMD5950x CPU.. 3090 GPU so the graphics side of things should be fine.. 64GB RAM.. HDX card in a thunderbolt external chassis.
____
I've seen some comments about plugins affecting things.. surely that's not a program-wide thing? I feel like even clicking File and Open Session is a little slower than I'm used to.
I do have a couple of outdated plugins though, for example I'm still on Autotune 8.1 and also Line6 Echo Farm, which is defunct as of 2020 I think. I really do doubt it's those though.
I am also using UAD OCTO & QUAD Satellites, via Thunderbolt, I seem to have occasional computer meltdowns with this, where the whole system needs to be restarted and/or BSOD occurs.. so perhaps it's a fundamental incompatibility between UAD and Windows.. the USB version seems to be just as buggy with Windows from what I've read.
Old 10-14-2024, 09:47 AM
tope d's Avatar
tope d tope d is online now
Default Re: 2024.6 VERY laggy and slow..
Just a note that only Intel processors are supported at the moment.
Best to optimize computer for Pro Tools use.
You can check https://avidtech.my.salesforce-sites...oting/en367983 for more info
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Old 10-14-2024, 10:35 AM
WAD WAD is offline
yeah I know that Intel but it's a bit of a non-issue tbh, I'm just wondering if this version is known for being a bit of a mess? I've been out of the loop since 2022.
and yes, all windows optimisations are in place
Old 10-14-2024, 02:57 PM
junkgear's Avatar
junkgear junkgear is online now
In general, no, that version is not known to be buggy or laggy.
Trying to find the source of your issue is probably going to take a little time since it requires starting with basically a clean PT install, with no plugins added and seeing how it performs. If things go okay, then you would typically reintroduce your plugins one at a time until you find the one that is causing the issue.
If your system doesn't run well even with a clean PT install, then you need to find the performance bottleneck in your system.
Will
System Details
Old 10-14-2024, 03:04 PM
WAD WAD is offline
As in take the plugins physically out of the plugins folder or just start blank session and gradually start using more plugins until it starts getting laggy and then you know which one it is?
Old 10-14-2024, 03:21 PM
dominicperry dominicperry is offline
Take them out of the folder. PT caches them on start up, so even if you don't use it on a session, a troublesome plugin can still screw things up.
Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Sequoia 15.2, Pro Tools 2024.10.2, Carbon.
2024.3.1 bugs - Calculating wavecache is very slow foret_sombre macOS 4 06-26-2024 01:27 AM
GetTrackList command still returns an empty array here - Pro Tools 2024.3/SDK 2024.3 GRT Pro Tools Scripting SDK Toolkit 6 03-19-2024 02:11 PM
Pro Tools Slow/Laggy fretfingers Pro Tools 11 25 07-15-2015 10:35 PM
Win 8.1 and protools 11.2 native laggy slow unresponsive. Wawili_Sound Pro Tools HDX & HD Native Systems (Win) 8 09-06-2014 11:04 PM
Laggy Unresponsive, Slow ECx VNC Remote Control audioman83 VENUE Live Sound Systems 6 10-29-2012 02:53 PM
