Old 04-09-2010, 12:22 PM
bfields28 bfields28 is offline
Default Native Instrument Maschine with PT8
Does the NI Maschine work with pt8? If so how in the hell do you record it on a track. Called NI and they said it will work but you have to use it in midi mode, but you won't be able to use any of the sounds on the Maschine. Also, what would be the best way to connect? I have it USB's into my Imac.
Should I run it through th 11r? Thanks fellas!
Eleven Rack
Axiom 25
Glyph 1T
Imac 3.06ghz, 4 g ram, 500g hdd
Old 04-09-2010, 02:52 PM
Creap Creap is offline
Default Re: Native Instrument Maschine with PT8
yes it works great. make an instrument track in pro tools and load the machine plug in on it. set the output of the instrument track to a bus. make an audio track to that bus and record.
Maschine STUDIO dose not appear in Instrument plugin in Pro Tools 10 MikeX2 Pro Tools 10 2 03-17-2014 07:23 AM
Native Instruments Maschine with Pro Tools [email protected] Pro Tools 10 2 09-10-2013 07:46 PM
Native Instruments Maschine in Pro Tools stebbi01 Pro Tools M-Powered (Mac) 1 11-06-2012 09:40 AM
Maschine as instrument plug-in in Pro Tools 10 enelbus Virtual Instruments 0 09-19-2012 08:26 PM
Native Instruments Maschine daslicht Virtual Instruments 7 04-30-2010 04:41 PM
