Protools commands & hexadecimal lenguage
hello, i have a yamaha 01v console and digi001, and i want to control the protools with the option remote of the 01v yamaha. where i can find a list of the functions of protools in hexadecimal lenguage?: for example i can discovery that for trasport play, the hexadecimal menssage is: f0 7f 7f 06 44 f7. i need a list of this funtions and config. for use the 01v yamaha as control surface. please help me!
thansk pd: sorry for my english
jesus sanchez |
Re: Protools commands & hexadecimal lenguage
Although I know they exist, there is no published list of systems exclusive midi commands for ProTools. (DIGI, are you out there? Why?)
However, you should be able to set up your 01v to emulate the JLCooper CS-10 controller using the information in appendix a in the ProTools MIDI Control Surfaces Manual . It's basically a list of what MIDI continuous controllers will control which ProTools parameters. Even the non-continuous parameters (mute, transport controls, etc.) are controlled by continuous controllers transmitting either 00h(on) or 7Fh(off) for the controller value. It's pretty silly, I know, but until Digi decides to publish a sysex command set, it's all we've got. Jason
Jason Romney Sound Design Instructor North Carolina School of the Arts www.cd-romney.com www.ncarts.edu/ncsaprod/designandproduction |
Do a search. Someone published a complete manual on how to use the o1v as a controsurface...
What's that? - That's the machine that goes "pling". Bastiaan |
im search in the web, but i not found any page for this. do you know any page please?
jesus sanchez |
All of the instructions I've seen are simply explanations on emulating the CS-10 which is already spelled out in the Pro Tools MIDI controllers guide.
You can set up everything that way and all the codes are laid out in the manual.
I said search...not search the web...and that was a hint... [img]images/icons/shocked.gif[/img]
I KNOW i saw a post right here on tghe duc explaining how to do it all...i just dont know where it went. I am sure a search will turn it up. It is only fair if you do some work for it to....hence i let you do the search... [img]images/icons/grin.gif[/img]
Protools 8 Help commands is not working | raviflute | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-02-2009 05:34 AM |
Protools Shortcuts in Logic key commands? | buckaroo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-01-2006 05:57 AM |
Key commands? | morganpage | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-11-2003 09:27 AM |
Protools commands & hexadecimal lenguage | mmestudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 12-23-2002 09:03 AM |
Voice commands in ProTools 5.0.1 | Denis N | General Discussion | 0 | 09-11-2000 04:31 AM |
