the PROPER way to copy/save PT sessions?
o.k., i've got two external hard drives and i want to save/back up a session from one to the other. how do i do this CORRECTLY, without winding up w/a bunch of empty regions with missing audio on the duplicate session? very frustrating!
Re: the PROPER way to copy/save PT sessions?
select - save copy in... check/tick all the bits you want and which drive you want to save them to. hit return. everything that you can do in the session you save from, you will able to do in the saved version. try making a test session. import a few files and save a copy. use pro tools to do the saving if you're not sure about moving files about. hope it helps.
Mac Computers/PT12/Lots Of Lacie D2s |
cheekypaul- thanks for taking the time to answer. that did the trick!
'Save Copy In' Archiving Sessions Question | skylab001 | Pro Tools TDM Systems (Mac) | 7 | 05-13-2011 02:09 PM |
Proper way to save session in previous PT version? | murray656 | Pro Tools TDM Systems (Mac) | 3 | 07-21-2009 12:33 AM |
"Save Session Copy in" occasionally doesn't copy.. | Willard | Pro Tools TDM Systems (Mac) | 0 | 03-06-2007 12:31 AM |
save sesssion copy x copy folder to another HD | Alécio Costa | Pro Tools TDM Systems (Mac) | 6 | 10-22-2002 09:29 AM |
"Save Session Copy" MUST copy AIIFF files??? | BHeller | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-11-2001 12:33 AM |
