Click from ProTools skips intermittently. Help
How do I keep the click sent from P/T plug-in from skipping while I'm tracking 24 channels @ 88.2k? It's not a tempo change, I'm set to manual tempo. I've reduced recording time to 10 minutes. Delay compensation in off. Sent audio to two different FW drives. 3 other sessions worked perfectly, now all sessions start to glitch. Can't think of anything else. I tried recording the click in as audio, still skips on playback from that while recording 23 other tracks. Just did a restart, blowing off the click for now (prepro), BUT I NEED IT TOMMOROW!!
Any ideas? |
Re: Click from ProTools skips intermittently. Help
What version of PT do you have?
I found the same problem with PTLE 7 (I'm a LE user) when using the Click plug-in on an Aux track. The click plug-in on an instrument track seems to be working fine. The safest way though, is dragging some cowbell/shaker samples into a tick-based audio track and use them as a click. You can put the cowbell sample on one track to mark the down beats and the shaker sample on another for the up beats. This way you can easily alter the volume balance between the two. R. |
v7.2, a recorded click track did it to. 23tracks recording, one on playback.
audio works, midi and click skips | nopoweroverme1 | Pro Tools M-Powered (Win) | 2 | 06-18-2010 04:38 AM |
VSS3 bypassing itself intermittently | zakco | Pro Tools TDM Systems (Mac) | 3 | 12-10-2008 02:05 PM |
Protools skips to end when i grab the scroll bar on bottom.. | broken81 | Tips & Tricks | 2 | 06-24-2008 01:32 PM |
mbox, ibook, protools- sounds works intermittently | vicsclipse | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-22-2006 05:36 PM |
Hardware not recognized, intermittently | dkapz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-31-2000 02:15 PM |
