Hi there,
this isn't directly related to Protools I know, but since some people on here work in music for tv/commercials (as I do) I thought I might find a suggestion or two! I have a Mac Pro (Late 2013) with an apple monitor which is all working fine, but decided to get a tv so that scoring to picture would be more widescreen. I have a Sharp tv (40UG7252K) hooked up via HDMI and it's all connected fine. The problem is that there is a lag of about 24frames+ on playback, which makes it impossible to use when working on tightly edited material. I noticed that the HDMI signal in to the tv is only 30Hz (the tv picture quality of the tv is 50Hz). Could this be the basic issue? Do I need to get a higher hz value on the tv? Or can I get something like an AJA T-Tap to improve the sync? Any advice would be a massive help! thanks!! Steve
Prism Orpheus, PT 11, Mac 2x2.26GHz QuadCore Intel Xeon, 16g ram Outboard - ADesign, Chandler, RetroDesign, Roland. |
![]() Quote:
Depending on Graphics card and Display (and the type of HDMI cable between the two) you should be able to put it at a resolution that works. Unless you are in Europe, the TV should be able to do 60Hz instead of 50Hz (technically 59Hz but it's close enough.) This is trial and error so expect your TV screen to blank out a few times and you might need to "gather windows" to try something else if you lose the screen temporarily.
Pro Tools Ult 2024.10.2, HDX 2, MTRX/SPQ, SyncHD, DNxiQ, RME BBF Pro + MADIface Pro S1 x 2, Fire Max11 x 2, Dock, iPad Air5 Mac Mini 14,12, 12 core, macOS 14.7.2 RAM 32GB, SSD 4TB, GPU 19 core QNAP TVS-872XT 148TB TB3 |
Last I checked Ireland is still in Europe
![]() I connected a Samsung 65” curved TV just a few weeks old to my MBP and it was super nice picture so you need to set the value to a much higher number than 30Hz
Ha. Totally missed looking at the top right location info.
Having this issue with delayed meters on my 2013 MBP/Catalina, connected to an LGTV via HDMI. I can't seem to change resolution, Hz or scaling properties from the Mac's display properties. Is there somewhere else to do it?
2012 MacBook Pro 15in, 2.3gHz,i7 2013 MacBook Pro 15in, 2.7gHz,i7 PT 2020.9.1 PT12.8.x |
![]() Quote:
You should have individual controls available for each display, including overscan for the TV. The settings windows may even appear individually on the separate screens (I can't remember). Hopefully you can find a more responsive setting for the LG. You should also try unplugging the LG and testing with only the MBP to be sure you're chasing the right troublemaker.
2023 MacBook Pro 15,8 (M3 max) Mac OS 15.4 (Sequoia) PT 24.10.2.205 (Ultimate) TB Native + Omni at home Apogee Duet 3 on the road |
Mirroring off, yes. I found a couple videos for LG TV's that mentioned enabling "Game Optimizer", which was the fix. The Gaming Optimizer settings are only showing 30fps? but, the Pro Tools metering is now as good on the LG TV as they are on the MBP screen.
Not sure if a better HDMI cable would change any settings options? In the Mac display settings, the underscan slider is greyed out for the LGTV, even when Scaled is selected. Hopefully this is helpful for someone else as well. Thanks!
HDMI connected LG 32" monitor | dr_daw | Pro Tools 2018 | 2 | 09-24-2018 10:24 PM |
LG 50" HDMI TV Monitor P/T 12.8.3 | EddieStrange | Getting Started | 8 | 01-15-2018 12:43 PM |
DVI -->HDMI vs. Thunderbolt monitor question | Guitarman002 | Pro Tools HDX & HD Native Systems (Mac) | 4 | 02-08-2017 12:15 AM |
PRO TOOLS HDX BUG FOUND! HDMI monitor the culprit! | adrianrobison | Pro Tools HDX & HD Native Systems (Mac) | 10 | 07-18-2014 06:56 PM |
Calculating Video offset hdmi external monitor | justanotherpostguy | Post - Surround - Video | 48 | 12-28-2012 12:31 PM |
