Euphonix MC Mix
I have just moved my little studio into my bedroom and in the process of setting things up. My MC MIX are connected to the ethernet port on my pc with windows 8. While the pc has a wireless wifi connection from the router in the livingroom 10 feet away. Should this cause any problem? I think the mc mix acts kind of strange and goes into a non responsive state from time to time.
And the icon on the menu bar is not green anymore like it used to be. It is now white instead. Starting as dark and turning into white. Is this normal? |
Wifi/bluetooth is never a good idea on a daw system and may cause problems.
Not questioning you but.. Would be nice to understand why. You often see a bluetoothkeyboard on for example the S6 surface.. Their new ipad control probably uses wifi.. Why would Avid promote the sliding S6 keyboard and their ipad app if it would not be good for your system.
D-control ES 32 - Venue Profile 48x24 - S3L-X - Yamaha DM2000 - Artist mix and control - HD7 accel - HDX2 / Magma EB3T HD native thunderbolt PT10HD 10.3.8. - PT11HD 11.3.2 2xHD madi - 2xHD omni - |
For the record, as someone with 30 years of technical computer and programming knowledge. You should not have problems running Wifi Internet with other Ethernet devices connected. On XP you would have had problems, however, the current iteration of just about every major OS should be fine.
I have been running my studio via wifi for the last six years with multiple different ethernet devices connected to a ethernet switch (AVB/Arist Series hardware, wifi printer, etc, no problems). Occasionally Pro Tools throws up playback errors, but it also consumes about 50% more of my CPU for the same task compared to something like Logic or Studio One, so it's more about Pro Tools not being optimised for the 21st century than anything to do with your network. And for the record, I get the same playback errors whether or not my bluetooth/wifi are on or off, so I will not be blaming wifi for that. IMHO, accepting that you can't use wifi internet on your computer/laptop while having other ethernet things connected because it may cause software problems is like telling someone not to roll the windows in their car down while air-conditioning is running, because the air-con will cause problems with the dashboard... it has nothing to do with the software. As I am typing this, I have an AVB interface connected to my Mac via Thunderbolt which gets an IP from the Mac, which I can then see on my wifi network (eg. other iOS devices), while my Mac is connected to a PPTP VPN into the office with an RDP session open. My 2 x Artist Mixes and 1 x Artist Control are up and running, with a Pro Tools session open, and my Yamaha Digital Piano connected via USB for Midi control. Zero issues. Have any questions or problems, PM me. :) |
Re: Euphonix MC Mix
no issue with wifi/ethernet here. just a mc mix user error.
Re: Euphonix MC Mix
Nor here.
I'm not sure about the icon colors but if it's working then don't sweat it. |
Re: Euphonix MC Mix
put all your ethernet devices together in a different network(different subnet), separate from the network where your wifi connection is in.
Pro Tools 11.2 Pro Tools 10.3.9 REAPER MPTK2 ProFire 2626 Benchmark DAC1 Neumann KH 120 A Avid Artist Mix ASUS Sabertooth Z77, Intel i7-3770K CPU OC'[email protected], 32 Gigs RAM Mac OS X 10.9.3 Mavericks |
Re: Euphonix MC Mix
Also the color of the icon is now dark grey/black in bolder text when connected, the green icon is gone since 3.1 so no worriess.
Euphonix with C8 | FluffyPost | ProControl, Control|24, Command|8 | 0 | 04-05-2012 10:41 PM |
Using UAD 2 With Euphonix | gclef101 | Artist Series | 15 | 01-08-2011 12:07 AM |
PT 8.0.3 - no more Euphonix MC Mix! | JustinA | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 12-23-2009 01:32 PM |
Euphonix MC+MIX and PT8 | manciosax | ICON & C|24 | 5 | 10-16-2008 07:47 AM |
7.4 HD and Euphonix MC Mix | Siegfried Meier | Pro Tools TDM Systems (Mac) | 3 | 08-26-2008 02:45 AM |
