Sync WAV and MOV (44100 samples and 23.98 fps)
Hello,
I have a video file that plays out of sync with an audio file when they appear to be lined up properly. I thought if I could somehow make the sample rate or fps or whatever on both files the same, they would sync up. I don't know if this is correct or not, and I'm not sure how to begin doing it. When I am importing the WAV file, it says "x can be added directly to the current session, but it will play back at the wrong speed." So I tried clicking Convert. No apparent help. My Session Settings are at default. Are there settings I need to change in Pro Tools when I'm importing the files? Do they need processing beforehand through some sort of third-party conversion software? My Pro Tools level of experience is Extreme Novice. Thanks in advance for any advice you can give me. Gateway DX4820 Intel(R) Core(TM)2 Quad CPU Q3800 @ 2.50GHz 2.50 GHz Windows 7 6 GB RAM Audio Interface: Roland Quad-Capture Pro Tools 10 |
Help!!! 44100 session plays 44100 samples slow | rhuenink | Windows | 1 | 03-27-2013 07:54 AM |
Sessions Losing sync at 4096 samples?? | Shazamm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 03-11-2012 09:04 PM |
Converting from 44100 to 48000 | Monstadrums | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 04-01-2008 04:39 PM |
44100 or 48000? | Notefarm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-19-2003 06:23 PM |
44100 or 44144??? | nukmusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-25-2002 11:01 AM |
