003 Rack + Midi Problems
HI, could anyone help me get my Midi I/O input enabled? After starting a blank session in PT LE 8.0.1, when I go to the setup tab and scroll down to MIDI Input enable there is nothing showing up in the box. It should be seeing the 003 Rack + driver in there as it does on a friend of mine's system. How can I get my 003 Rack + to show up in the Midi enable box in order to use my Yamaha KX8 keyboard with all the wonderful virtual instruments? The 003 rack green light lights up under the MIDI in on the interface when the keys are depressed, but the software is not recognizing the 003 Rack + driver. How do I get the driver installed so it will be recognized by the software? Please help. Thank you.
Re: 003 Rack + Midi Problems
Is MMERefresh.exe running in Task Manager? Try trashing Digidesign Databases and DAE Prefs, reboot your pc, and relaunch PT. When I had this problem, I uninstalled and reinstalled PT to fix it. You are right though, that the 003 should show up under MIDI Input Devices.
Hi, thanks for the reply. Yes MMERefresh.exe is running in the task manager. How would go about removing the Digidesign Databases and DAE Prefs in order to try that? sorry, I havent been running Pro Tools for very long and I'm kinda a newbie at this thing. Please accept my apologies. please advise. Thanks.
One thing to remember, Turn on your 003, turn on your midi device, (at this point will usually touch a key and watch the Midi IN light on the front of the unit to see if it lights up, then I start PT. If I start PT at the same time as the 003 my Midi devices never show up.
Peace!
Here I am, after time not long... and thankful for the break, What I found when I got there, was that I couldn't stay away! Hobo Shave! |
Go through the General Troubleshooting thread:
http://duc.digidesign.com/showthread.php?t=133039 it explains deleting the databases and preferences as well as many other optimizations you should make. |
How about your problem with MIDI right now?
Did you ever find a solution to this? I'm having the same problem with my 003 Rack - on Windows Vista and with LE 8.0.3cs2
11 Rack Midi and Customer Service Problems | Quantum Cat | Eleven Rack | 7 | 10-17-2012 01:47 PM |
Problems with the MIDI Outs on my Digidesign 003 Rack | septik | MIDI | 0 | 01-14-2012 12:34 PM |
Digi 003 Rack, Pro Tools 9 MIDI problems | Hobson81 | macOS | 1 | 09-14-2011 01:03 AM |
003 Rack Midi output problems | kimmie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-29-2008 01:53 AM |
002 rack midi problems | allsopp | MIDI | 1 | 10-19-2006 05:42 PM |
