Old 02-16-2008, 11:19 AM
gar_lei gar_lei is offline
Default No core audio for 7,4???
Hello
I just installed PTLE 7,4 on my MacPro (Hapertown)
At first it says installation failed when I was installing PTLE 7,4.
BUt after I tried installing 7,4cs2, then it says installation suceed and I was able to launch Protools without problem.
But the weird thing is, I can't find my Core Audio Manager...
Does PTLE 7,4 suppose to have it?
Thanks
Old 02-16-2008, 12:53 PM
Phil Ogden Phil Ogden is offline
Default Re: No core audio for 7,4???
Core Audio usually installs by default as part of the standard Pro Tools installation.
What OS ?
Does PT play back through the Digi interface (you don't say which) OK?
What can you see in System Prefs/Sound or after launching AudioMidi set-up in Applications/Utilities?
http://www.myspace.com/philogg
Old 02-16-2008, 11:20 PM
Hello
I'm on 10,5,2
I tried it on 10,5,1 before, same result...
I have Digi002r and I tried to play a song through iTune and it doesn't play through my Digi002r.
And in system preferences/sound, there's only built-in audio...
I'm clueless what happens here...
Old 02-17-2008, 03:18 AM
Few users have managed to get PT working reliably with Leopard. A qualified version of PT LE for Hapertown processors is probably not too far away given the support in the recent HD release. However, until this time, the only thing I can suggest is the dual boot workaround put forward by Digidesign.
Pro Tools LE® are currently not compatible with the Mac OS X 10.5 (Leopard) operating system. Pro Tools HD 7.4.1 software for 8-Core Mac Pro models works with Mac OS X 10.5.1 only, and is NOT compatible with Apple’s new Mac OS X 10.5.2 release. Please do not update your OS until we’ve made an official announcement about compatibility.
For the latest information, check the Product News section of the Digidesign website regarding upcoming support:
Information on Pro Tools Compatibility with Mac OS X Leopard — Updated February 11, 2008
For all systems other than Pro Tools HD 7.4.1 for Mac Pro:
If you choose to upgrade to Mac OS X 10.5 (Leopard), you will need to install it on a separate hard drive or drive partition. To use Pro Tools LE or M-Powered 7.x currently, you will need to boot from a Mac OS X 10.4 (Tiger) startup system.
Digi 002-using FW & core-audio drivers to output audio to mac WITHOUT using ProTools DaveZ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 04-12-2012 12:53 PM
core audio conects , but no audio passing threw audiomania Pro Tools TDM Systems (Mac) 2 08-23-2006 07:41 AM
Pcie core + Core audio + Tiger, does it work? fantomaz Pro Tools TDM Systems (Mac) 0 12-21-2005 01:04 PM
Problems w/Core Midi and core audio MBox 6.1 letrev 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-03-2003 01:43 PM
Will the core audio driver enable audio units ? linpaws 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-16-2003 02:01 AM
