#741
I was unaware that this could be an issue... is this known? Any fixes besides adding a firewire express card?
It would make sense, since I am now having DAE loading issues at startup. I think this thing is going back to Dell this week, and I'm going the Macbook Pro route.. this last week of trying to make it work has taken more than a few years off of my life. Quote:
#742
I think this is what you need. I'm running, or trying to run, PT 6.7 off this laptop with a 002R. The 002r is working fine w/ my ableton, but PT won't start up. When I double click it, it gives me the blue screen of death. Please help!
Ben SiSoftware Sandra System Host Name : COMPUTER User : Sklerms Workgroup : WORKGROUP Processor Model : Intel(R) Pentium(R) M processor 2.13GHz Speed : 2.13GHz Performance Rating : PR2554 (estimated) Cores per Processor : 1 Unit(s) Threads per Core : 1 Unit(s) Type : Mobile Internal Data Cache : 32kB Synchronous, Write-Back, 8-way set, 64 byte line size L2 On-board Cache : 2MB ECC Synchronous, ATC, 8-way set, 64 byte line size, 2 lines per sector Mainboard Bus(es) : ISA PCI PCIe IMB PCMCIA CardBus USB FireWire/1394 MP Support : 1 Processor(s) MP APIC : Yes System BIOS : American Megatrends Inc. 0208 System : ASUSTeK Computer Inc. M7V Mainboard : ASUSTeK Computer Inc. M7V Total Memory : 1GB DDR2-SDRAM Chipset 1 Model : ASUSTeK Computer Inc 82915PM/GM/GMS, 82910GML Host Bridge Front Side Bus Speed : 4x 133MHz (532MHz data rate) Total Memory : 1GB DDR2-SDRAM Memory Bus Speed : 4x 133MHz (532MHz data rate) Video System Monitor/Panel : Default Monitor Monitor/Panel : Default Monitor Monitor/Panel : Plug and Play Monitor Adapter : NVIDIA GeForce Go 6600 Physical Storage Devices Hard Disk : ST9100823A (93GB) CD-ROM/DVD : TSSTcorp CD/DVDW TS-L532A (CD 24X Rd, 24X Wr) (DVD 3X Rd, 3X Wr) Logical Storage Devices Hard Disk (C:) : 20GB (219MB, 1% Free Space) (NTFS) Storage (E:) : 74GB (4.2GB, 6% Free Space) (NTFS) Removable Drive (F:) : 968MB (968MB, 100% Free Space) (FAT) Pro Tools LE (D:) : 478MB (CDFS) Peripherals Serial/Parallel Port(s) : 1 COM / 0 LPT USB Controller/Hub : Intel(R) 82801FB/FBM USB Universal Host Controller - 2658 USB Controller/Hub : Intel(R) 82801FB/FBM USB Universal Host Controller - 2659 USB Controller/Hub : Intel(R) 82801FB/FBM USB Universal Host Controller - 265A USB Controller/Hub : Intel(R) 82801FB/FBM USB Universal Host Controller - 265B USB Controller/Hub : Intel(R) 82801FB/FBM USB2 Enhanced Host Controller - 265C USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub FireWire/1394 Controller/Hub : OHCI Compliant IEEE 1394 Host Controller PCMCIA/CardBus Controller : Ricoh R/RL/5C476(II) or Compatible CardBus Controller PCMCIA/CardBus Controller : Ricoh R/RL/5C476(II) or Compatible CardBus Controller Keyboard : Standard 101/102-Key or Microsoft Natural PS/2 Keyboard Mouse : Synaptics PS/2 Port TouchPad Communication Device(s) Device : HDAUDIO SoftV92 Data Fax Modem with SmartCP Printers and Faxes Model : Microsoft Office Document Image Writer Power Management AC Line Status : On-Line Battery No 1 : 42% Operating System(s) Windows System : Microsoft Windows XP/2002 Professional 5.01.2600 (Service Pack 2) Network Services Adapter : Marvell Yukon Gigabit Ethernet 10/100/1000Base-T Adapter, Copper RJ-45 Adapter : Intel(R) PRO/Wireless 2915ABG Network Connection Performance Tips Notice 5901 : CD 1x= 150kB/s; Exercise caution when comparing measured versus published ratings. Notice 5902 : DVD 1x= 11.08Mbps Exercise caution when comparing measured versus published ratings. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. |
#743
![]() Quote:
This is a very common and asked about problem, especially with older versions of the software (i.e. 6.7)
#744
I need or need to find the authorization code for my protools le 6.7 I lost my getting started guide while i was moving and I tried to install protools on my other laptop but need code i still have protools on my laptop i use for recordig now can u help????
#745
breal, like I said in your other identical post, You need to contact Customer Service Directly:
This is a user's forum; no one here can give you that information. (not without breaking the law and the Digi EULA, anyway) Digidesign wouldn't give it to you over a public forum anyway, and you have no private contact information listed.
#746
Hallo! I'm sure you've seen this a lot on here, because I've read about it a lot...
H/W Buffer errors!!!! My problem started about 4 days ago when I started getting "Access Violation" Errors. I could not save, and sometimes open, any session to my recording drive, the ST3200822A (186GB) listed below. Well I got on here and in the General Troubleshooting thread found a suggestion of deleting the digidesign database folders from my drives. I did that and that error did not occur anymore. However... I am unable to use PT as anything more than an overblown audio player now. I get frequent Hardware Buffer errors -6088 and -6085 I believe they are. The -6085 tells me to reduce, the -6088 tells me to increase. I get the -6088 the most and it tells me that the operating system held off interrupts for too long. I have no idea what this really means. All I know is I can listen to my tracks in PT to an extent, and can not bounce ANYTHING out. Even with no plugins up I get this error. I record at 88.2 kHz. I've done all of the optimization steps that I will admit I did not do before this problem...because well, I HAD NO PROBLEMS. Since Jan., I've not had one issue with my system until now. I had the Mbox 1 for about 3 years prior to getting my current hardware, the 002R. Not one problem outta that thing. HELP ME PLEASE. I lost $150 this past weekend because I had to cancel two sessions! Anyhow, another problem I've found is that when I'm not running PT and I'm using the 002R as my sound card, I get stops and stutters like I'm playing a scratched CD. I'm loading .wav files into my windows media player for heaven's sake! One suspicion is that I have a problem with the transfer of data from my PC to the 002R. Watching the 1394 led on the 002R, I'm finding that it blinks...which is NOT SUPPOSE TO HAPPEN I'M SURE. I don't see any responses after these posts in here so please tell me you guys are PMing the assistance or something and we're not just posting to post here. I've been a loyal PT customer since 2002. I really would like to remain one. Thanks. SiSoftware Sandra System Processor Model : AMD Athlon(tm) XP 2000+ Speed : 1.67GHz Model Number : 2000 (estimated) Performance Rating : PR2427 (estimated) Cores per Processor : 1 Unit(s) Threads per Core : 1 Unit(s) Internal Data Cache : 64kB Synchronous, Write-Back, 2-way set, 64 byte line size L2 On-board Cache : 256kB ECC Synchronous, Write-Back, 16-way set, 64 byte line size Mainboard Bus(es) : AGP PCI IMB USB FireWire/1394 i2c/SMBus MP Support : 1 Processor(s) MP APIC : Yes System BIOS : Award Software International, Inc. F8 Mainboard : Gigabyte Technology Co., Ltd. GA-7VT600 Total Memory : 1GB DDR-SDRAM Chipset 1 Model : Giga-Byte Technology VT8377 Apollo KT400/A/600 CPU to PCI Bridge Front Side Bus Speed : 2x 134MHz (268MHz data rate) Total Memory : 1GB DDR-SDRAM Memory Bus Speed : 2x 201MHz (402MHz data rate) Video System Monitor/Panel : Delta DB-770 Adapter : NVIDIA GeForce2 MX Imaging Device : Lexmark 3300 Series Physical Storage Devices Removable Drive : Floppy disk drive Hard Disk : ST3200822A (186GB) Hard Disk : WDC WD400BB-00DKA0 (37GB) CD-ROM/DVD : DVDRW IDE1108 (CD 40X Rd, 40X Wr) (DVD 5X Rd, 5X Wr) CD-ROM/DVD : SONY DVD RW DRU-810A (CD 40X Rd, 40X Wr) (DVD 5X Rd, 5X Wr) Logical Storage Devices SYSTEM 1 (C:) : 20GB (9.4GB, 48% Free Space) (FAT32) SYSTEM 2 (D:) : 18GB (17GB, 96% Free Space) (FAT32) Sessions (F:) : 186GB (140GB, 75% Free Space) (NTFS) Pro Tools LE 6.9 (E:) : 512MB (CDFS) CD-ROM/DVD (G:) : N/A 3.5" 1.44MB (A:) : N/A Peripherals Serial/Parallel Port(s) : 2 COM / 1 LPT USB Controller/Hub : VIA Rev 5 or later USB Universal Host Controller USB Controller/Hub : VIA Rev 5 or later USB Universal Host Controller USB Controller/Hub : VIA Rev 5 or later USB Universal Host Controller USB Controller/Hub : Standard Enhanced PCI to USB Host Controller USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Composite Device USB Controller/Hub : USB Printing Support USB Controller/Hub : Generic USB Hub FireWire/1394 Controller/Hub : OHCI Compliant IEEE 1394 Host Controller Keyboard : Standard 101/102-Key or Microsoft Natural PS/2 Keyboard Mouse : Microsoft USB Wheel Mouse Optical Human Interface : HID-compliant device Human Interface : USB Human Interface Device Human Interface : Microsoft USB Wheel Mouse Optical MultiMedia Device(s) Device : MPU-401 Compatible MIDI Device Device : Standard Game Port Printers and Faxes Model : Lexmark 3300 Series Model : AGFA-AccuSet v52.3 Power Management AC Line Status : On-Line Operating System(s) Windows System : Microsoft Windows XP/2002 Professional 5.01.2600 (Service Pack 2) Network Services Adapter : Realtek RTL8139/810X Family PCI Fast Ethernet NIC Performance Tips Warning 100 : Large memory sizes should be made of Registered/Buffered memory. Tip 2546 : Large memory modules should be ECC/Parity. Notice 5901 : CD 1x= 150kB/s; Exercise caution when comparing measured versus published ratings. Notice 5902 : DVD 1x= 11.08Mbps Exercise caution when comparing measured versus published ratings. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
Win7 64 Ultimate - Intel Core i7-920 Bloomfield 2.66GHz - Gigabyte EX58-UD3R - OCZ Gold 6GB - Radeon X550 256MB Video Card - 750GB Caviar Black System, 500GB Hitachi SATA Sample, and 750GB Caviar Black Audio - 500GB Caviar Blue Backup - Pro Tools 8.0.4 LE - Signature Series Digi 002R ![]() |
#747
i would really apreciate if someone could give me some help here, i bought a mbox2 a few days ago, with ptle 6.8, i did everything the manual said to do before instaling, and once the instalation had startedand was at about 86% done my pc crashed, i had to restart but pt wont open at all, i tried to uninstall it, re-install it, everything but it just wont even uninstall now and when i try to install it again it always gives me an "component tranfer error" in the file group "PT folder icon", the file "<iconPath>" and the instalation fails, i dont know what to do, i tried deleting manually all digidesign files but it still wont install, to make things worse now my pc crashes constantly whenever i try to make pt work, im desperate, please help
SiSoftware Sandra System Host Name : GASTON-R1LTX75O User : Gaston Workgroup : SEISA Processor Model : Intel(R) Pentium(R) 4 CPU 3.20GHz Speed : 3.19GHz Performance Rating : PR4245 (estimated) Cores per Processor : 1 Unit(s) Threads per Core : 2 Unit(s) Internal Data Cache : 16kB Synchronous, Write-Thru, 8-way set, 64 byte line size, 2 threads sharing L2 On-board Cache : 1MB ECC Synchronous, ATC, 8-way set, 64 byte line size, 2 lines per sector, 2 threads sharing Mainboard Bus(es) : AGP PCI IMB USB FireWire/1394 i2c/SMBus MP Support : 1 Processor(s) MP APIC : Yes System BIOS : Intel Corp. RL86510A.86A.0075.P15.0404021333 Mainboard : Intel Corporation D865PERL Total Memory : 511MB DDR-SDRAM Chipset 1 Model : Intel Corporation 82865G/PE/P, 82848P DRAM Controller / Host-Hub Interface Front Side Bus Speed : 4x 200MHz (800MHz data rate) Total Memory : 512MB DDR-SDRAM Memory Bus Speed : 2x 200MHz (400MHz data rate) Video System Monitor/Panel : Monitor Plug and Play Adapter : MSI MS-StarForce GeForce FX 5500 (NVIDIA GeForce FX 5500) Imaging Device : Genius VideoCAM NB Physical Storage Devices Removable Drive : Unidad de disquete Hard Disk : ST380011A (75GB) CD-ROM/DVD : LITE-ON CD-RW SOHR-5238S (CD 52X Rd, 52X Wr) CD-ROM/DVD : LITE-ON DVDRW SOHW-1633S (CD 48X Rd, 48X Wr) (DVD 6X Rd, 6X Wr) Logical Storage Devices Hard Disk (C:) : 39GB (19GB, 49% Free Space) (NTFS) Hard Disk (D:) : 35GB (19GB, 55% Free Space) (NTFS) CD-ROM/DVD (E:) : N/A Pro Tools LE (F:) : 316MB (CDFS) 3.5" 1.44MB (A:) : N/A Peripherals Serial/Parallel Port(s) : 1 COM / 1 LPT USB Controller/Hub : Intel(R) 82801EB USB Universal Host Controller - 24D2 USB Controller/Hub : Intel(R) 82801EB USB Universal Host Controller - 24D4 USB Controller/Hub : Intel(R) 82801EB USB Universal Host Controller - 24D7 USB Controller/Hub : Controladora de host universal USB2 Intel (R) 82801EB - 24DD USB Controller/Hub : Intel(R) 82801EB USB Universal Host Controller - 24DE USB Controller/Hub : Concentrador raíz USB USB Controller/Hub : Concentrador raíz USB USB Controller/Hub : Concentrador raíz USB USB Controller/Hub : Concentrador raíz USB USB Controller/Hub : Concentrador raíz USB USB Controller/Hub : USB Composite Device FireWire/1394 Controller/Hub : Controladora de host VIA OHCI compatible con IEEE 1394 Keyboard : Teclado estándar de 101/102 teclas o Microsoft Natural PS/2 Keyboard Mouse : Mouse PS/2 de Microsoft Human Interface : Dispositivo de juego compatible con HID Human Interface : Dispositivo de interfaz humana USB MultiMedia Device(s) Device : FlyVideo 2000 Device : SoundMAX Integrated Digital Audio Printers and Faxes Model : Microsoft Office Document Image Writer Model : Detectando automáticamente Microsoft Office Document Image Writer en GASTONLT Power Management AC Line Status : On-Line Operating System(s) Windows System : Microsoft Windows XP/2002 Professional 5.01.2600 (Service Pack 2) Network Services Adapter : Adaptador Fast Ethernet PCI CNet PRO200 |
#748
Hi.
Trying to set-up an Mbox with Pro Tools LE 6.4 on a friend's PC. I've been using Pro Tools for 4 years, but never on a PC and we are having some problems with the audio. 1. For starters, I set up a click track and the click is muffled and distorted. It sounds really strange. 2. Next, when I tried to record audio using a XLRs and a a number of different Mics, I get no sound from the Mic. 3. I tried to plug a guitar directly into the Mbox and the guitar sound comes through the speakers and headphones, but it doesn't register a signal within Pro Tools. 4. I tried to import in MP3 file to an audio track so I could at least show him some editing basics, but the MP3 file comes through all distorted and muffled. - When I say distorted and muffled, think like how Charlie Brown's mom's voice sounds. I know all the connections are fine and setting on the Mbox are good. I've been using it forever, but never on a PC. I've tried multiple mics and cables. Something is happening either with the Mbox itself or within the PC that is not allowing the audio to register in Pro Tools. Here is is set-up: Dell Dimension Desktop Intel Pentium (R) 4 CPU 2.80GHz 2.79GHz, 504MB of RAM Windows XP Home with Service Pack 2 PLEASE HELP! |
#749
Hi JayRock,
did you find out what was wrong with your config? I'm very interested to know because I have almost the same laptop - Inspiron 9400 with T2400 processor. Thanks in advance! |
#750
SiSoftware Sandra
System Host Name : DAMAGE-BLING User : Eric Draevyn Workgroup : MSHOME Processor Model : AMD Athlon(tm) 64 Processor 3200+ Speed : 2.01GHz Model Number : 3200 (estimated) Performance Rating : PR3015 (estimated) Cores per Processor : 1 Unit(s) Threads per Core : 1 Unit(s) Internal Data Cache : 64kB Synchronous, Write-Back, 2-way set, 64 byte line size L2 On-board Cache : 512kB ECC Synchronous, Write-Back, 16-way set, 64 byte line size Mainboard Bus(es) : ISA PCI PCIe USB FireWire/1394 MP Support : 1 Processor(s) MP APIC : No System BIOS : American Megatrends Inc. 8.14 System : MSI MS-7250 Mainboard : MSI MS-7250 Total Memory : 2GB DDR2-SDRAM Chipset 1 Model : Advanced Micro Devices (AMD) Athlon 64 / Opteron HyperTransport Technology Configuration Front Side Bus Speed : 2x 1005MHz (2010MHz data rate) Total Memory : 2GB DDR2-SDRAM Memory Bus Speed : 2x 251MHz (502MHz data rate) Video System Monitor/Panel : Hitachi CM801 Adapter : NVIDIA GeForce 7300 GT Physical Storage Devices Removable Drive : Floppy disk drive Hard Disk : WDC WD2500YD-01NVB1 (234GB) CD-ROM/DVD : HP DVD Writer 740b (CD 40X Rd, 40X Wr) (DVD 5X Rd, 5X Wr) Logical Storage Devices Hard Disk (C:) : 39GB (19GB, 49% Free Space) (NTFS) Storage (D:) : 195GB (176GB, 90% Free Space) (NTFS) CD-ROM/DVD (E:) : N/A 3.5" 1.44MB (A:) : N/A Peripherals Serial/Parallel Port(s) : 1 COM / 1 LPT USB Controller/Hub : Standard OpenHCD USB Host Controller USB Controller/Hub : Standard Enhanced PCI to USB Host Controller USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Composite Device USB Controller/Hub : USB Composite Device FireWire/1394 Controller/Hub : VIA OHCI Compliant IEEE 1394 Host Controller Infrared Device : Built-in Infrared Device Keyboard : Standard 101/102-Key or Microsoft Natural PS/2 Keyboard Keyboard : HID Keyboard Device Keyboard : HID Keyboard Device Mouse : HID-compliant mouse Human Interface : HID-compliant device Human Interface : HID-compliant consumer control device Human Interface : USB Human Interface Device Human Interface : USB Human Interface Device Human Interface : USB Human Interface Device Human Interface : USB Human Interface Device Printers and Faxes Model : Auto HP DeskJet 830C/832C on DAMAGE-DESK Model : Auto Adobe PDF on DAMAGE-LAPTOP Model : Adobe PDF Power Management AC Line Status : On-Line Operating System(s) Windows System : Microsoft Windows XP/2002 Professional 5.01.2600 (Service Pack 2) Network Services Adapter : NVIDIA nForce Networking Controller I wish I could list off error codes for you, however, PTLE 6.7 causes a hard reboot every time I try to open it. Any help is greatly appreciated. N. |
Problems with PTLE? Post your configuration here...... | still_life_ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-30-2007 12:27 AM |
Problems with PTLE? Post your configuration here.. | DJ John | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 08-28-2007 10:06 AM |
Problems with PTLE? Post your configuration he | krsongs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-28-2007 09:59 AM |
Problems with PTLE? Post your configuration here.. | p3tch | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 08-28-2007 09:46 AM |
Problems with PTLE? Post your configuration here.. | Gaba | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 08-23-2007 08:01 AM |
