Old 02-16-2022, 01:24 AM
Dejenerate Dejenerate is offline
Default IPAD wont connect thru USB
Hi folks,
Have a problem.
The iPad cannot be connected to the EU-con via USB Cable. The operating system is OS Catalina, until Mojave everything worked normally.
Thank you in advance
Old 02-17-2022, 05:31 AM
Default Re: IPAD wont connect thru USB
Originally Posted by Dejenerate View Post
Hi folks,
Have a problem.
Presumably you have the latest Eucon version . .
I would suggest un install Eucon. Restart then re install. . .
During the install you should be asked to allow Eucon access to your ports. .
If you're not asked this, go to system settings, privacy & search for Eucon to check that it has access to your ports . .
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG
~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~
Old 02-17-2022, 06:00 AM
its2loud its2loud is offline
Hi folks,
Have a problem.
When you say USB cable, I assume you’re using the USB camera connection kit along with a usb Ethernet adapter? Not just the charging cable that came with the iPad?
Can’t connect second iPad tbstudio Avid S1, S3, Dock and Control App 1 03-09-2021 09:28 PM
Second iPad won’t connect to Control app tbstudio Avid S1, S3, Dock and Control App 0 03-09-2021 09:55 AM
How do you hardwire connect both Dock and iPad" Cherub1 Pro Tools 12 0 06-04-2016 05:07 PM
Can't connect ipad to Eucon CharlotteMichele Avid S1, S3, Dock and Control App 4 09-28-2015 02:32 PM
iPad Teleport fails to connect to Venue Profile ShawnMitchL VENUE Live Sound Systems 11 07-01-2013 09:45 PM
