Fairchild 670 ~ External Side Chain ?
Hi all. .
Does anyone know of an AAX 670 that has external side chain facility ? Any help much appreciated . . Cheers . .
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~ ~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG ~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~ |
Re: Fairchild 670 ~ External Side Chain ?
Only one that I can find that has one is the Avid 670 in the Complete Plugins bundle.
Yes, but that doesn't behave correctly. It seems to use the "key" input & the source material. .
Are you saying the sidechain uses both the external sidechain along with the internal sidechain (if you have an external sidechain feeding into the plugin)? Please explain.
With LAT/VERT engaged & a signal going in the key input, behaviour is not as required. .
Try it. On a stereo channel obvs . . Seems to me there isn't really an external sidechain capability with the 670. . Unlike other compressor plugins, which all have either a "key" or "external" button. If it was properly implemented it would have a "key" or "ext" button + a toggle to select which path the sc is acting on. LAT or VERT.
Exactly. Sent from my iPhone using Tapatalk
Avid. Any chance of this being implemented ?
I have a feeling it might well be popular. And while you’re at it… ADC & stereo side chains please … Thanking. After all… your software is called “Pro” Tools. Sent from my iPhone using Tapatalk
Seeing this thread just made me realise that the two Fairchilds I have from Waves and IK don't actually have a sidechain either... WTF?!?
I do have the SPL Iron though. It's fundamentally based on a similar design, but they took it a lot further. It, at least, has a sidechain and by setting it's Bias to High and choosing a good Rectifier setting you can kind of get close. As long as you aren't one to split hairs!! |
Do you know, , , ? That's exactly what I did. . ! Nice bit o kit is Iron . Thank you for your reply / suggestion .
Is it possible to side-chain an EQ? | Herkimer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-03-2009 06:00 PM |
Impact Side Chain | J2sound | VENUE Live Sound Systems | 5 | 07-14-2009 05:50 PM |
How do I set up a Side Chain | junglelabs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 09-30-2007 10:49 PM |
Side Chain | ByPass | Tips & Tricks | 1 | 05-08-2007 12:33 PM |
A better way to side chain? | studiojb | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-24-2007 04:40 PM |
