S1 Custom Color Key commands Stopped Working
Hey gang. Need some ideas from everyone.
So for some reason today, one of my custom commands that I had programmed to be the /Alt color key on my S1 has stopped working. I had it set to open and close folder tracks. (shift+f). Now no matter what I do, or what color key I try to program with that key command, it will no work. It will not open or close the folder track. All the other commands are working fine. If I press shift+f on my keyboard, the folder track opens and closes properly. Any ideas? I've deleted preferences. I've restarted everything at least twice. I'm on the latest eucon software. Thoughts? sleiweke 2019 Mac Pro Rack 3.3 GHz 12-Core 96 GB RAM OS12.6.3 HDX Pro Tools 2023.3 Lynx Aurora (n) 32 2 Avid S1's |
Re: S1 Custom Color Key commands Stopped Working
Remove and then re-add MC_Client and EuControl from macOS Privacy & Security > Accessibility
You can do a restart between the remove and then the re-add. (I say this because this is a keyboard command vs a Eucon command which usually means the issue is macOS not listening to Eucontrol as a keyboard. And that is controlled by Accessibility needing to treat Eucontrol like a human interface device/keyboard)
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
That did the trick! Thanks so much for your help.
sleiweke 2019 Mac Pro Rack 3.3 GHz 12-Core 96 GB RAM OS12.6.3 HDX Pro Tools 2023.6 Lynx Aurora (n) 32 2 Avid S1's |
Econ custom commands in 2021 | mattrixx | Pro Tools | 4 | 03-27-2021 09:17 AM |
Custom key commands | @tention | macOS | 2 | 12-15-2018 03:03 PM |
Custom Key Commands - broken? | EdgarRothermich | Pro Tools 12 | 9 | 10-09-2016 09:32 AM |
Artist Color & custom wheel/ball commands? | surroundsfx | Artist Series | 2 | 01-19-2012 02:40 PM |
Assigning Custom Key Commands | lexaudio | Pro Tools TDM Systems (Mac) | 7 | 07-13-2011 03:54 PM |
