Old 05-05-2021, 12:46 AM
ihate100bees ihate100bees is offline
Default Install flags PT Helper file as Malware?
Win 10 Pro
64 bit
Didn't have an issue with 2021.3... but when removed and installed 2021.3 1 my Webroot anti virus sees the Pro Tools Helper file as Malware? Software will run but nothing shows up when entering any drop down in Help. Have downloaded several fresh times from my Avid account. Never had a problem with any updates since 12.5 . What is happening? Thanks
Old 05-05-2021, 04:18 AM
Default Re: Install flags PT Helper file as Malware?
Originally Posted by ihate100bees View Post
Win 10 Pro
64 bit
The usual instruction for any s/w install is to disable anti-virus when installing for just this reason. Unplug from the net, disable anti-virus, install, reboot, re-enable anti-virus. Done.
Jack
QAPLA!
Old 05-05-2021, 07:01 AM
Correct. I did disable Webroot antivirus as well as Windows Defender when downloading the new version and installing. Then, after rebooting system I enabled antivirus back on again. Web Root still catches it. Then I tell it to ALLOW the file. When I run the newer 2021.3.1 software and try to open the help menu..., none of the drop downs hold any information and an error message comes up. Never did this before.
Old 05-05-2021, 07:56 AM
FWIW, Windows Defender has never flagged Avid software
Old 06-03-2021, 08:22 AM
BoBlue BoBlue is offline
This is happening to me. Webroot says Pro Tools Helper is malware and suggests I remove it. It seems to not make sense to "disconnect from the net and reinstall" The install process gets Pro Tools from the net, right? Anyway, my question is a) can I simply remove Pro Tools Helper as Webroot suggests? or b) can I just ignore Webroot, and leave ProTools Helper intact? My gut instinct now that I know Pro Tools Helper is not malware is to simply ignore Webroot and leave well enough alone.
Old 06-03-2021, 11:46 AM
That^^^ or kill the Webroot process in Task Manager before running the installer. When the system reboots after the installer finishes, Webroot will be active again with nothing required from you.
Old 06-03-2021, 12:46 PM
I think Webroot did a more critical update this year and that's why it is catching it. I told Webroot too "Allow it" . No problem after that. I wanted to keep the Helper so that's what worked for me. Otherwise, every time you open Pro Tools, it will stop it.
Install Helper? Mitch Griffin Pro Tools 12 0 12-04-2015 10:37 PM
Pro Tools is trying to install a new helper tool - Every time it's run gregsmith macOS 4 11-21-2014 11:22 AM
Article/Fluent News Aniti-Malware gives Pro Tools TDM Systems (Mac) 0 06-19-2010 10:02 AM
