Old 12-13-2011, 03:20 PM
tkicker4 tkicker4 is offline
Default Bar|Beat Marker - Beat Detective
I've got the structure of my session sectioned off by markers. I am now trying to adjust the tempo of each individual section of the structure so that the beginning of each section corresponds with the bar|beat markers using beat detective. I got the first one (1>2) to work fine, so now I've got other sections that are starting at a point that doesn't line up with the grid. For example, section 3 starts at 32|1|440 instead of 32|1|000. When I try to adjust the other sections, say 2>3 or 3>4 etc., I am getting the following error:
the bar|beat marker(s) could not be created because they are either too close or too far apart from a neighboring bar|beat marker to support a valid tempo.
Any ideas how to get this to work?
Thank you,
Adam
Old 12-15-2011, 09:12 AM
glennaudio glennaudio is offline
Default Re: Bar|Beat Marker - Beat Detective
I would use Identify Beat (command + I).
separate the section of the songs by splitting the waveform into different regions. (command + E to split at selection). You can use "Tab to transient" to quickly find the down beat of a section. if you select the section of the song, press command + I, and tell Pro Tools what measure numbers the start and end points are supposed to be at, Pro Tools will make the tempo line up with the song.
You might need to erase whatever tempos you already have plotted in your tempo map. Also, if you're unable to identify beat, toggle the "conductor" icon in your transport.
Hope this helps. Let me know if you have any questions.
Pro Tools Carbon | HD Native 2021.12 | HD I/O 8x8x8 | UA 4-710D | Avalon VT737 | Waves Mercury | Komplete 13 Ultimate Collector's | Kontrol S61 | Maschine Studio | Eleven Rack | Pro Tools Control w/ 9.7" iPad Pro | Pro Tools Dock | S1 | MacPro 7,1: 16-core 96GB RAM W5700X GPU OS 11 1TB SSD +OWC 1m2 2TB SSD (samples) +Sonnet M.2 4x4 4x2TB Samsung Evo Plus SSDs in RAID 0 (sessions)
Old 12-30-2011, 09:38 PM
Thanks Glenn, I wound up obtaining a tempo map and used Identify Beat and everything worked out.
Thanks again!
Beat Detective Cmd+Click Won't Add Marker tmaclean macOS 6 04-13-2013 06:40 AM
Tempo mapping Beat Detective or identify beat? grateful 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-14-2012 09:13 PM
Grid and Bar/Beat Markers scrambled and disabled after using Beat Detective!! Robbry Pro Tools M-Powered (Win) 0 02-24-2010 02:14 PM
what do grid lines do after beat detective bar-beat markers cc1 Pro Tools TDM Systems (Mac) 1 05-22-2007 09:34 AM
Beat Detective, Beat markers to Tempo Ruler?!? phobia Tips & Tricks 3 01-01-2007 01:31 PM
