Mbox 2 Pro audio cuts out
Hi there,
I have seen quite a few post concerning audio cutting out on Mbox Pro, 2, 3 models... I have an Mbox Pro2 hooked up via firewire to my MacBook Pro running Snow Leopard 10.6.8. It has always worked fine then out of the blue it started cutting out audio after a few minutes playing itunes or ableteon or any audio playback program. The firewire seems to be still on although sometimes lights to the Mbox Pro2 seem to cut out altogether. I have updated firewire drivers to the (2&3) models of Mbox Pro updated firmware updated all my applesoftware also after I change the clock source from internal to clock and back internal audio will start playing back again but then it will cut out after a few minutes. Driving me insane and I have a show next week. Considering ditching the digidesign hardware if this continutes although some forums have suggested it is an Apple issue. Any help please!!!! |
Re: Mbox Pro2 audio cuts out
Can you post your full system specs? What driver version are you running? I think the other threads you are referring to are Mavericks 10.9+, that should not be the same problem you're having. Did you do any changes to your setup when the problem started (OS updates, new software, drivers etc)? You might want to try another firewire cable too.
Joel
Jam Space: HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Home: Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Rig: Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM |
MacBook Pro
Snow Leopard 10.6.8 Mbox Pro2 ProTools LE 8 Processor 2.66 GHz Intel Core !7 Memory 8 GB 1067 MHz DDR3 Startup Disk Macintosh HD I totally need to try a new firewire cable. Probably will get one today. I figured it works b/c usually the light stays on on the mbox pro 2 although rarley it cuts out completely. I updated my driver after the problem started to what the avid website lead me to which was an update Mbox pro2 and 3 users. Not sure how to find which driver I am using thoough. The odd thing is now it has been working all day today (been working on music for a solid 3 hours) Gonna try the new firewire , thanks |
PT LE audio cuts out during playback | illiotic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-08-2011 10:50 PM |
Mbox cuts out? Help | Flan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 12-16-2007 05:15 PM |
mbox 2 sound cuts out | ophillip | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-31-2007 12:34 PM |
BTD cuts off the end of the audio. Why? | SteveGarman | Pro Tools TDM Systems (Mac) | 2 | 05-27-2005 05:03 PM |
Audio cuts out! HELP! | rossi21 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-26-2005 10:49 PM |
