Cannot set more then 8 out of 16 cores
I've got a shiny new Mac Pro 2.26 gHZ dual quad (8 core) and while performance is generally spectacular, I discovered early on that if I set more then 8 cores active in System Settings I would get CPU spikes and general instability.
Now, this is 8 cores out of 16 possible cores (PT reads the 8 cores as 16 cores with hyperthreading). Anyone else experiencing this? I'm aware that one should set less cores active then one physically has to let the OS do it's thing, but am I seeing the best possible performance with 8 cores enabled? And with a hyper-threaded system, what does 8 cores even mean? Does that mean 4 cores are active?
Greg Nicolett, Film and TV Composer www.gregnicolett.com ------------------------------------------------ Pro Tools LE v8.03 Digi 002r w/ DV Toolkit 2 Mac Pro 2.26 gHZ 12 GB RAM Snow Leopard 10.6.3 |
Re: Cannot set more then 8 out of 16 cores
Surely someone is using LE on an 8 core machine and can comment on this? PT shows 16 virtual cores due to hyperthreading. Anyone getting any success running more the 8 out of 16 cores in System Settings?
Mine shows 16 cores and I have it set at 15 (leaving one for non-realtime plugins) and everything is running fine. I'm not sure if it runs better than setting it at 8 cores but it runs fine at 15. I have no CPU spikes or instability of any kind.
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
I have a dual quad core as well and I leave mine just set at 4 cores. It works flawless.
Mac Pro Dual Quad 2.8Ghz 2008 MacBook Pro i7 2012 OSX 10.8.5 - OSX 10.7.5 Pro Tools 10.3.7 - 11.1.2 6GB RAM Universal Audio Apollo Quad!!! Eleven Rack Focusrite Octopre MKII Yamaha HS80s Rockit RP5 Monitors w/ RP10 sub |
Mine shoots to 99% CPU usage with 15 cores enabled. Running Kontakt 3.5 and Kontakt 4.1 in the session (3.5 is not approved by Digi), though multi-processor support is disabled in Kontakt per suggestion.
I'll have to do more research and report back in a few days....
It was actual the first version of Kontakt that worked extremely well. I thought that's what most were running - well at least those not updating to K4. I don't have issues with it. |
I've removed Kontakt 3.5 from the plugins folder and I belive all of my other plugins are up to date and supported. I still cannot select more then 8 cores on my 2009 Mac Pro without CPU usage shooting up to 70-80% and getting a distorted, pop ridden playback experience.
What other info can I provide, Avid, to get to the bottom of this?
Have you tried to move all 3rd party plugins out of the plugins folder, trashing preferences, rebooting? That way you should be able to check if DTS's advice was the right direction...
Mac Pro 8-core 2.26 | 6 GB | OS X 10.6.8 | PT LE 10.0.0 | MBox 2 / ECHO AudioFire PRE8 MacBook Pro i5 2.3 | 4 GB | OS X 10.6.8 | PT LE 10.0.0 | MBox 2 / ECHO AudioFire PRE8 |
Problems when using all 4 cores vs. 3 cores | hopelessennui | macOS | 1 | 02-03-2012 06:54 AM |
PT9 using 16 cores ONLY out of 24 - DTS? | Zarabozo | Windows | 54 | 11-19-2011 09:39 AM |
Mac Octo 2.26: Almost no difference between 2 Cores and 8 Cores | Hive Guy | macOS | 8 | 05-10-2011 11:05 PM |
better performance from 7 cores than 15 cores? | stevesound | macOS | 4 | 03-30-2011 11:48 AM |
how many cores PT LE can use? | evs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-09-2008 01:22 AM |
