Old 02-27-2024, 03:01 AM
SUNG HOON LEE SUNG HOON LEE is offline
Default Can digidesign 192 i/o work with Protools 2022.7?
Mac OS 12.6
Protools 2022.7
Old 02-27-2024, 03:07 AM
Default Re: Can digidesign 192 i/o work with Protools 2022.7?
Yes... but only if you have a HD Native, HD Native Thunderbolt, or HDX Card and Pro Tools Ultimate. You must have Ultimate not lower versions which do not support any Digilink interface.
Old 02-27-2024, 01:23 PM
BScout BScout is offline
You also need the adapter cables to connect from new digilink (screw on) to old digilink (spring clamp). You can find them on ebay used. Make sure you get the right male/female ends (that depends on if you want to use old or new digilink cables so the adapter either goes card side or interface side.) But there are 2 versions of the adapters for this reason.
Getting the Command 8 to work with PT 2022.12 on Win 10 64bit unkJE ProControl, Control|24, Command|8 3 01-11-2024 11:35 PM
Plugin automations doesn't work in Pro Tools 2022.12 alan_trjop Pro Tools 10 02-10-2023 09:40 AM
2022.12 - Random Tracks don't Work - Solved Sanny Pro Tools 2 12-29-2022 04:05 PM
What versions of Pro Tools 2022 work with Eucon 2022.9 Mixmaster Rick Pro Tools 2 12-28-2022 01:13 PM
TC POWERCORE, UNIVERSAL AUDIO UAD1- let them work with Protools LE please Digidesign! Slovenec 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 12-18-2001 08:26 AM
