Old 02-26-2024, 12:15 PM
dittybox dittybox is offline
Default Issue with Playlist Names Changing When Cycling Through Playlists in Pro Tools
Hello fellow Pro Tools users,
I've encountered a behavior in Pro Tools that I'm hoping to get some clarity on. When I use the Command+Shift+Down Arrow (on Mac) to cycle through material in the Edit selection from the next playlist, I've noticed that once I've cycled through all the playlists and returned to the starting playlist, the name of the playlist changes (the number at the end goes up continuously.)
Here's a screen recording for context
https://drive.google.com/open?id=1mK...9&usp=drive_fs
To my understanding, when cycling through playlists, once you return to the starting playlist, a "home" icon should appear, indicating no clip edits are made, and any previous clip separation edits are healed. However, I'm also observing a change in the playlist name, which seems unintended.
Is this a standard feature, or could it be a bug? If it's a feature, what could be the rationale behind the automatic renaming? I'm looking to understand this better to streamline my workflow and avoid any unnecessary confusion.
Thanks in advance for your insights!
Bug? Audio cycling in a selection skips to first or last playlist moshuajusic Pro Tools 2019 2 01-14-2020 12:27 AM
Auto-Created Playlist names 3peacestudios Pro Tools 12 2 11-25-2016 12:00 PM
SOS. Phantom Playlists and Playlist Correspondence Problems jschmidtiii macOS 0 10-19-2013 05:50 PM
Track names vs Playlist names bredo Pro Tools 10 6 01-07-2013 08:29 AM
Suggestion: Separate Track and Playlist names ashdot ICON & C|24 0 07-03-2001 10:41 AM
