Old 03-02-2015, 12:11 PM
Tim R. Tim R. is offline
Default Master Faders not getting ADC when Offline bouncing
I realize there may still be nagging ADC issues with VIs, but this thread is NOT discussing those problems.
My ADC issue is with Master Fader processing not being compensated for when doing offline bounces. I have a master fader assigned to each of my record busses (primary and stems). After I do an offline bounce and spot back my audio the clips are off by the exact amount of reported delay on the master faders. For clarification, here's my signal path:
Source audio track is routed to a "sub-master" bus. There are AUX channels with the Sub-master bus for an input and a "Record Master" bus for an output. There are Master Faders for each record bus. If you compare a real time record pass (to an audio track) with an Off-line bounce (spotted) they are off by the exact amount of reported delay on the Master Fader.
Tim Reisig
Main System: Pro Tools Ultimate 23.12, HD Native TB, HD OMNI, S3/Artist Transport/Eucontrol 22.20, Apogee Rosetta 800 w/XHD card, Avid 96 I/O
Mac OS 13.2.1, 2018 Mac Mini 3Ghz i5, 32Gig RAM
System 2: Pro Tools 23.9 (no Hardware), Mac OS 13.2.1, MBP (Macbook Air M2, 2022 24Gig Ram)
Old 03-02-2015, 01:18 PM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Master Faders not getting ADC when Offline bouncing
How about realtime bounce?
Janne
Old 03-08-2015, 08:30 PM
Took me a while to get back on my home (PT11) system.
Real time bounce does NOT exhibit this problem. Real time bounce (spotted) matches a real time record record to tracks exactly. ONLY Off-line bounces are NOT compensating for master fader processing.
Tim Reisig
Old 03-11-2015, 11:19 AM
Anyone else care to confirm or deny experiencing this issue so perhaps AVID can address?
Tim Reisig
No offline bouncing ??? maxon Pro Tools 10 33 11-27-2012 09:20 AM
Command 8 Offline and not moving faders DJElBee ProControl, Control|24, Command|8 5 10-04-2011 03:31 AM
offline bouncing? production Pro Tools 9 1 11-07-2010 09:07 AM
Offline bouncing Logic with MC Mix torsig1967 Artist Series 2 11-03-2010 12:13 PM
Help-faders 'fluttering' when offline OntheHill ICON & C|24 2 05-19-2009 11:09 AM
