  #81
Old 08-20-2014, 04:21 AM
Marco Bernardo's Avatar
Marco Bernardo Marco Bernardo is offline
Default Re: Is the Avid IO fan quieter than the 192 fan?
Originally Posted by the19thbear View Post
You dont have to use a voltmeter:) Just make sure that you dont short the 2 wires that are coming from the actual avid unit. You cant burn anything as long as you dont do that, and i dont even think you actually can burn anything if you even did short the wires.
You have a red and a black wire. Red is + and black is - or ground, coming from the Avid unit. On your new fan you will have 3 wires. All grey i think.. Just try out a combination, using your fingers to hold the wires together - you cant get any electric shock since the current is so small.
When you hit the right combination it works. Since its only 1 redundant wire, it takes about 30 seconds to find out which one it is, just by trial and error.
Nice thanks
Cheers
Ill keep in touch
Marco Bernardo
Dialog Editor, Sound Designer, Re-Recording mixer
nMacPro 6Core/D500/512GB/64Gb ram | PT HD 12 HDN Thunderbolt | HD OMNI | Avid Artist Mix | Novation Impulse 25 | Waves Mercury Native | Audioease All In Bundle | SoundToys | McDSP Classic Pack | DUY Overpack | Arturia Beatstep Pro
  #82
Old 08-20-2014, 04:22 AM
JFreak's Avatar
JFreak JFreak is offline
Default Is the Avid IO fan quieter than the 192 fan?
Out of three wires it takes 5 seconds to find the two that work. Then it takes another 5 seconds to find out if the fan blows air in or out. Then it takes 10 seconds to solder the wires an another 10 seconds to wrap some isolating tape around :)
Janne
  #83
Old 08-23-2014, 10:49 AM
DONE!
It was very fast, about 20 minutes to make this fan replacement.
Everything it's running perfect, no fan error (till now)!
I just want to thank you all for all the help/info.
Cheers
ps:If anyone need some pictures, just pm me
Marco Bernardo
  #84
Old 01-22-2015, 06:13 AM
Skwaidu Skwaidu is offline
Fixed my HD IO with the silenx fan http://www.silenx.com/quiet.fans.asp?sku=efx-08-15
Most time went into replacing the connector but it was doable, I ordered some spare 4-pin extension cables so I have the original fan intact if I need to reinstall it.
The end result is stunning. Nearly dead silent from somewhat annoyingly loud, my quite quit AC now overpowers the tiny fan noise left. Shame on Avid for leaving such a design flaw into their premium product.
Windows 11 23H2, Intel i9-14900KS, MSI PRO Z690-A D4, 64 GB DDR4 4000MHz/CL18, Corsair HX1000, 1TB M.2 PCIe 4.0, 5TB M.2 PCIe 3.0, 2TB QVO, 2x6TB WD Black, Noctua NH-D15, Fractal Design Define R6 + RTX4070 - PT Ultimate 2024.3
Used to be/ Spare/ DAPS: Mac Pro 4,1 upgraded to 5,1 3,46Ghz 12 Core, 96GB RAM, OS SSD and Sata3 Audio SSD, macOS Mojave, PT Ultimate 2021.10, DAPS 3.7.1
HDX2, MTRX Studio & DAD MOM, HD I/O 16x16, Apogee AD/DA 16X/X-HD and ICON D-Command ES.
  #85
Old 02-22-2024, 03:56 AM
foret_sombre foret_sombre is offline
Upping this thread since some of us still use old HD Omnis.
Do you know where to buy Silenx IXP 11-14 in Europe ? I can't find any that ships to France (except from the US with massive shipping prices).
I tried replacing it with a Noctua NF A4x10 which had the same characteristics but it gives a Fan error (even if it runs). Tried changing the polarity, letting it run for some time, nothing works.
Need a new quieter fan to HD IO.. JCDC Pro Tools HDX & HD Native Systems (Mac) 139 03-25-2023 01:31 PM
Are the new HD 8x8 i/o's quieter than the last gen? guitarzzan Pro Tools 9 2 06-16-2011 10:52 PM
Quieter internal drive for new mac pro? bsmith23 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 10-26-2009 04:48 AM
G4 quieter fan exchange Seller Pro Tools TDM Systems (Mac) 0 02-21-2003 08:53 PM
Which PC's are quieter? MGruschow 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-03-2000 11:25 PM
