  #21
Old 04-24-2013, 05:23 PM
Meads Meads is offline
Default Re: Is the Avid IO fan quieter than the 192 fan?
What I do not understand though is, why don't they use a fan that is $10 more (at the most) and quiet, and charge the buyer $15 more for the unit? $15 really don't matter in that price range, I would think. And everyone would be happy.
Since this is such an obvious solution I wonder why instead they assume most of the buyers have machine rooms, so it doesn't matter how noisy they are. I find that to be a weird, ignorant and unnecessary mindless approach.
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24 | S3 | Dock
  #22
Old 04-24-2013, 05:25 PM
sound_music sound_music is offline
for what it's worth, after installing the latest 2.10 firmware on the omni (which was quite a lot of trouble in itself--but that's a little off topic here), the fan noise dropped considerably.
i had it sitting on top of a rack beside the console while setting it up and testing, and although much better after the update, i could still hear it. now it's installed in another rack further away and it's barely audible.
moral of the story is do the firmware upgrade, and rack it, and it should be fine.
  #23
Old 04-24-2013, 05:27 PM
i had it sitting on top of a rack beside the console while setting it up and testing, and i could still hear it after the update, but now it's installed in another rack further away and it's barely audible.
It's not about the Omni, it's about the HD I/O. The fan noise of the Omni got a whole lot better after the update, that's true. But the HD I/O still is about as loud, as the Omni has been before.
iMac Pro
- MacOS 10.14.6
- C|24 | S3 | Dock
  #24
Old 04-25-2013, 03:47 AM
paulo m's Avatar
paulo m paulo m is offline
At one of the places I work, they upgraded to the new HD I/O units. It´s only one per room and they are fitted in side racks under the Icon´s surfaces.
To be honest, I never heard the fans so far. Maybe because the racks are deep or it has to do with the rooms acoustics, but so far, no fan noise problems.
Regards,
Paulo M
MAC Studio MAX M1_64 GB RAM_1TB SSD_MAC OS Ventura
Protools Studio 2024.3
  #25
Old 04-25-2013, 10:37 PM
MixerGuy MixerGuy is offline
how long is the warranty on an HD I/o?
and
I agree - the fan in an HD I/O is ANNOYING.
and
I will swap the fans - once the boxes are out of warranty. I own 2.
  #26
Old 04-26-2013, 02:08 AM
JFreak's Avatar
JFreak JFreak is offline
Originally Posted by Meads View Post
AFAIK you have to pull off the connector from the cable of the old fan, and put it on the cable of the new fan, since the HD I/Os connector is 4pin as opposed to the new fan's which is 3pin. (or you splice the cables, same thing)
Question - are the cores always color coded the same way? So replacing red with red and black with black - no possibility of wrongdoing here?
Most usually they are, but obviously there is no guarantee of that.
Red = positive DC power
Black = negative DC power
Don't know what other wires there may be, probably some kind of control trigger thing..?
Janne
  #27
Old 04-26-2013, 02:12 AM
Well, the replacement fan's wires are all black, so that's that.
So one has to look up, how the 3pin connectors usually are assigned.
The third wire of the 3 pin connector of the fan is for speed control.
The 4 pin connector of the HD I/O has only two wires assigned, the other two are empty.
iMac Pro
- MacOS 10.14.6
- C|24 | S3 | Dock
  #28
Old 04-26-2013, 05:12 AM
JFreak's Avatar
That is easy then; the fan without speed control will likely operate at full speed at all times. Two black wires are DC power so worst thing that can happen is the fan rotates at wrong direction if the power input is not regulated.
Janne
  #29
Old 04-26-2013, 07:37 AM
Eric Lambert's Avatar
Yes, always verify the direction of airflow after installing the new fan. Drawing heat INTO the box would be bad.
  #30
Old 04-26-2013, 07:40 AM
Yes, I am aware.
But I'm not going to do anything, until the case with Avid has come to a final conclusion.
iMac Pro
- MacOS 10.14.6
- C|24 | S3 | Dock
Need a new quieter fan to HD IO.. JCDC Pro Tools HDX & HD Native Systems (Mac) 139 03-25-2023 01:31 PM
Are the new HD 8x8 i/o's quieter than the last gen? guitarzzan Pro Tools 9 2 06-16-2011 10:52 PM
Quieter internal drive for new mac pro? bsmith23 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 10-26-2009 04:48 AM
G4 quieter fan exchange Seller Pro Tools TDM Systems (Mac) 0 02-21-2003 08:53 PM
Which PC's are quieter? MGruschow 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-03-2000 11:25 PM
