Old 07-06-2011, 12:44 PM
DJElBee DJElBee is offline
Default Command 8 Offline and not moving faders
My Command 8 after working flawlessly for 7 months all of the sudden it's offline and the faders show no sign of life the play and stop button works and now I have a great looking paperweight good thing I haven't shelled out for the C24 yet PLEASE HELP!!!
Old 07-06-2011, 12:47 PM
browniespeaks browniespeaks is offline
Default Re: COmmand 8 Offline and not moving faders
more info
Clifford Brown III
Brown Audio Solutions & Services
www.brownaudio.com
Old 07-06-2011, 02:47 PM
Brownie didn't understand
Old 09-28-2011, 03:42 PM
DigiTechSupt's Avatar
I think what browniespeaks was saying is that we need more info about your system, configuration and what you've tried so far to solve the problem - because that's exactly what we need to know.
Please see the Help Us Help You thread for information on the specific details we need to know to troubleshoot the problem you're having.
Avid Audio Tech Support
Support FAQ
Old 09-30-2011, 09:58 AM
TDub TDub is offline
Default Re: Command 8 Offline and not moving faders
Hey DJElBee,
I've had this happen a few times and drove me nuts trying to figure it out. Recently i did the following and it fixed it! Quick and easy!
Go into C Drive ... Program Files ... Digidesign folder ... Command 8 folder ... then find the digidriver and double click to instal it. Click install. Voila. No guarantees, but it seems to work for me every time lately. Not even sure why this message came up for me after it working so well for so long, but ... either way. Give it a try. No guarantees, but seems to work for me.
Good luck.
TDub
Digi002 R with Command 8 - PTLE 8.03
Intel Quad Q9550
Asus P5Q Pro
Win XP
4GB
Old 10-04-2011, 03:31 AM
andymac andymac is offline
This has happened to me quite a few times
Im using an Icon 8, but assume it would be the same procedure.
I usually have to go to the Setup/Peripherals/Ethernet Controllers menu and force it to re-scan for devices (tick the "enable" button, then click the ethernet port drop down menu and scan all available ports).
The post above sounds like it may be a better long term solution though!
D-Command Offline jim2step ICON & C|24 3 04-27-2010 09:52 AM
Help-faders 'fluttering' when offline OntheHill ICON & C|24 2 05-19-2009 11:09 AM
PT command for moving all small faders? GroovnD313 Pro Tools TDM Systems (Mac) 1 11-06-2007 09:13 AM
command 8 REALLY OFFLINE frewno ProControl, Control|24, Command|8 0 10-31-2006 08:23 AM
Command|8 Going Offline Chief Technician ProControl, Control|24, Command|8 19 08-16-2005 05:58 PM
