Old 02-24-2011, 04:12 PM
cortinaone cortinaone is offline
Default Strike 1.5 bug - importing samples
Hi there,
I'm running Snow Leopard PT9 and Strike 1.5 is playing up when importing samples. Basically as soon as the finder window opens up to browse for samples, Pro Tools hangs and then crashes. I haven't been able to find anyone else on the net with the same issue. Is there anyone on this forum that is having this happen to them?
I should also add that the same thing happens on my other macbook running PT8
Cheers
Old 02-25-2011, 09:57 AM
daslicht daslicht is offline
Default Re: Strike 1.5 bug - importing samples
sounds like the same issue with Structure where protools crash when you try to browse...
Import samples Strike 1.5 broken? magnoman Pro Tools TDM Systems (Mac) 0 03-30-2011 06:19 AM
Importing samples Lockiepeds Pro Tools M-Powered (Win) 3 06-24-2010 06:30 PM
Strike Samples octel1 The Drum Room 2 06-17-2010 01:10 PM
Some of Strike Samples will not play Drive d Virtual Instruments 4 12-14-2006 04:36 AM
Importing EMU ESI32 samples into Samplecell Siegfried Meier Pro Tools TDM Systems (Mac) 1 03-16-2002 11:10 AM
