Old 02-08-2011, 07:47 AM
friendlybunny friendlybunny is offline
Default Pro Tools dropping tracks at 96 khz
I searched and searched and couldn't find an answer.
I normally work in 48 khz, but I just got a session that was recorded in 96 khz, 24 bit. There are not many tracks, and the session only uses up 20 voices. When I play back the system using 6 processors for 96 voices, only half of the files will play, and I will get pops and clicks from some of the tracks. I starting reducing the amount of processors and the tracks will randomly change which tracks will play, and which ones will not. I finally lowered the playback engine to 1 processor for 24 voices, and all of the tracks played. There are no plugins at all and it is a stereo session.
My system is Pro Tools 9.1, TDM HD2 accel, Mac Pro 2.8 quad core, OSX 10.6.6, Digi 96 i/o.
Old 02-08-2011, 09:52 AM
Default Re: Pro Tools dropping tracks at 96 khz
I tried the critically low on memory adjustment trick, and it seemed to fix my problem.
http://duc.avid.com/showthread.php?t=293512
dropping tracks - need deaactive then make active to recover fork-media Pro Tools 10 13 10-14-2013 07:03 AM
Is there any way I can get 128 instrument tracks without dropping 2 grand?? Violet Pro Tools 9 10 10-18-2011 12:18 AM
bounced tracks not dropping in properly cali9dub 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 16 09-17-2009 05:37 PM
midi tracks dropping levels while recording elv1s1sal1ve 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-03-2008 08:16 PM
tracks dropping out... terryd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-04-2005 07:38 PM
